Question about Electrolux E23CS75SS Air Conditioner
Blowing out warm air
My split system is blowing out warm air when it is set to cool and the lowest temp possible?
  • Anonymous Mar 30, 2014
    Have just moved in and am trying to get warm house I have tried setting warmer tried hold temp but still blows coolish air and won't get higher than 22c its Honeywell heating cooling roof ducted model number T8132A1049 also do these run gas or ele
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
This could be a refrigerant leak. Before you call out a service technician, clean the filters and then try to see if it works. If it doesn't then get the unit serviced.
Hope this helps
I take the time to answer your questions, so please rate me.
Mat
Posted on Aug 30, 2009
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Replace blend door actuator motor
Could be, check the door and see if it works correctly
Aug 17, 2013 | Mitsubishi Cars & Trucks
Fridge freezing up
Set your Ref/Freezer per the following:
Refrigerators:
36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
Nov 23, 2012 | Spartan Showcase Self Service Cigarette...
Our split system is not blowing cool air all the time? Can you tell me what the problem might be. Thanks
To get proper cool, keep cool mode. Temp setting minimum 3 degree less than room temp.Check indoor coil,air filter and blower wheel are cleaned.
Check gas pressure is good by keeping your hand on suction pipe (bigger size) which gives chillness.
Hope, helpful.
Jan 28, 2011 | Samsung Heating & Cooling
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
My remote controller of the split type machine have two keys such as 'TOO COOL ' AND 'TOO WARM' . May I get the information about functioning of these keys in which situation use .
If you press Too Warm, temp will automatically 3 degree goes down as setting temp. and same when you press Too Cool, set temp will raise + 3degree.
In your remote set temp is 24 and you press Too Warm, set temp becomes 21 and same in Too Cool will become 27. It's normally in O'General a/c May be 2 differ in other units instead of 3degree. Thanks, and helpful?
Jan 21, 2011 | Heating & Cooling
Good after noon i have a Starway Split Wall Mount Reverse Cycle Air Con. the problem i have is when i need to warm my house the air coming from the system is cold. even with the temp setting on the sun...
Examine the condenser. The condenser pushes the air and expels the warm air from the air condition to the house. Also check the fan heater on your system to see if it is functioning, because if it is not, it will circulate the heat from the unit to the house, in this case,it will need to be fixed. also check if the thermostat on the unit is regulating because if it is not regulating, you will not get the house to warm due to bad thermostat, check to ensure it is regulating, if not, replace it, it might be defected because that is the key to regulate the unit. so pay attention to it to see if it regulating the unit, if not, replace as advice.
Take care.
Jun 12, 2010 | Heating & Cooling
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Heating & Cooling Logo
449 people viewed this question
Top Electrolux Heating & Cooling Experts
Cris Sparks
Cris Sparks
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
