Defunct cd drive
My gateway notebook will no longer recognize cds! Everytime I put a cd in the drive it will whirl like its about to play and then send the message "there is no disc in the drive". Any suggestions that are ideally suuuuuuper easy? : - ). This problem began after installing a hard drive. The hard drive worked fine, and then was also no longer recognized by my computer and to make it work, I have to manually check songs in order to put them in my ipod. Could the two problems be related? I would so appreciate your help.
Your friendly computer idiot.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    you can try to clean the lens inside..but be careful not to get any liquid inside..
    otherwise, those are cheap and easy to replace..you can find a replacement online easy..knowing the model nubmer of the computer helps too.
    Guru:
  • 257 Answers
Thats ok my friend, What you have to do is that your system is selecting the kind of hardware that will work with it.
So u go online and find the same product and maker for the cds and harddrive ok
Or you get the cd drive out and check for Dusting the part both lens and some hollowed part of it ok
or the problem with that kind of cd you want to play may be a corrupted cd for the system.
Aright , make use of that and please, rate this Solution.
bye.
Posted on Oct 16, 2008
Why won't cds play in the dvd-rw?
Nathaniel, DVD RW have the capability of playing any CD. If you are facing problem then either:
a) Your CD is not right or has too much scratches on it.
b) Your DVD RW Lens has gotten a bit weak. Clean your DVD RW lens and then give it a try.
Oct 31, 2012 | Compaq Presario CQ60-204NR Notebook
Emachine T3882 with DVD Rom issue
  1. Click Start
    , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK.
  4. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  5. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  6. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. .
  10. On the Edit menu, click Delete.
  11. When you are prompted to confirm the deletion, click Yes.
  12. Exit Registry Editor.
  13. Restart the computer.
Oct 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd drive does not work.
When you interrupt the boot sequence and go to the BIOS screen, does it recognize that there is a device at that point. If not it looks like the CD drive is U/S. If it does recognise it at BIOS ... try reloading the drives for the CD ... or upgrade to the latest.
Cheers,
Ripface.
Sep 26, 2009 | Gateway M675 Notebook
Cd drive makes noise on startup, wont accept any cds
Sounds like the drive is broken, is this for a personal pc or a business pc?
May 21, 2009 | Gateway M-1615 PC Notebook
Cd drive not recognizing cd's
nope it happens to me, if your laptop still under warrantee call toshiba and they will replace it to you. the problem is the lens not reading the cd, try to clean it by dvd cleaner if its not working replace it.
Mar 19, 2009 | Toshiba Satellite M115-S3094 Notebook
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
I want to play mini cds in a standard slot drive in laptop.
You should notice in your cd tray a smaller cutout in the center. That is specifically for mini cds.
Jan 14, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
WinXP Pro - can't install from my original CD
Can you read the CDs in the windows? If not, the CD drive was dead.
Nov 16, 2008 | Gateway MX6920 Notebook
Can't READ or PLAY CD/DVD in DVD drive
Many laptops allow you to detach the CD/DVD drive - if this is the case for your laptop, perhaps it is slightly loose, or been removed by Safely Remove Hardware. You could try physically taking the drive out, and putting it back in, and that might do the trick.
Feb 14, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
David Payne
David Payne
