Question about Project Justice for Dreamcast
How to solve
We have a project in tomcat webapps directory name myproject for example
for requesting this project then we need to type http://localhost:8080/myproject
but my problem is instead of localhost i was *.localhost (abc.localhost or pqr.localhost etc)
can we do that in the local machine
if we can do it then please tell me the procedure
Thanks
manoj
In vista how to use the del command
open a dos prompt.
to make a directory type md "name of directory"
to remove a directory type rd "name of directory"
to change from one to another type cd "name of directory"
to go up one directory type cd..
to change drives type cd drive letter
All commands are typed without quotes
Mar 20, 2014 | Microsoft Windows Vista Home Premium with...
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
How to transfer files from one partition to another using dos command?
hi if you wont move command
then try
go to the source dtive
[ example c: ]
then
move filename sorce_address source filename dest_address destnation_filename
example c:\>move text.txt d:
if you wont copy use copy insted of move
if you wont copy/move all files
then
c:\> copy *.* d:
if any problam replay me
May 02, 2011 | Microsoft Windows XP Professional
How do i restore the directory
If you want to restore the directory hierarchy that contains the examples and sample programs that shipped with the calculator
  • Press [alpha][alpha] to lock the alphabetical keyboard.
  • Press [TEACH] then [ENTER).
  • The programs and examples will be restored.
If you want to create a directory (from scratch)
  1. Press [Right Shift Cyan key] and [HOME] to get back to the main directory.
  2. Press [Right Shift Cyan key] [VARS] to access (MEMORY) management
  3. Press the [D:New] tab
  4. The new variable screen opens
  5. Use the DownArrow twice to move cursor to the third line (_Directory)
  6. Press [C:Chk] to put a Check mark to the left of Directory
  7. The screen will change to show [Name and Directory]
  8. Use Up Arrow to move cursor to the first line (Name)
  9. Press [A:edit]
  10. Enter the name and then press [F:OK]
Once the directory is created you can use the Memory management to copy OR Move objects from other directories to the new one.
May 10, 2010 | HP 48gx Calculator
In RPL mode, put the object on the stack. Enter the name you want for the directory (must not conflict with an existing object) between ticks and press STO.
Mar 18, 2010 | HP 48gx Calculator
How do i start tomcat server?
I ll share config steps that I use:
1) After installing the Tomcat server set the environment variables in the following way :-
a)var name:path
var value:C:\Java\jdk1.5\bin;C:\Tomcat 5.5\bin
b)var name:classpath
C:\Tomcat 5.5\webapps;C:\Tomcat 5.5\common\lib\servlet-api.jar
c)var name:JAVA_HOME
d)var name:CATALINA_HOME
Var Values:C:\Tomcat 5.5
2)After setting these variables check to see if the server is running by typing "http://localhost:8080/" in the web browser.
3)If you can see the Apache Tomcat page with the message "If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!" then everything is fine & server is well configured.
I havent tried it on Win 2000 yet, these steps I use to configure Tomcat on Win XP & Vista, hope this proves to be of some help to you too.
Apr 29, 2009 | Computers & Internet
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Error 158
FDirSync: Err Msg: Error [158] Requestor Not Registered View products that this article applies to. function loadTOCNode(){} Article ID : 99268 Last Review : October 30, 2006 Revision : 1.1This article was previously published under Q99268 SYMPTOMS loadTOCNode(1, 'symptoms'); When a Foreign DirSync, Directory Synchronization with Foreign Mail Systems, message comes into the DirSync directory server, these error messages may appear:
In DIRSYNC.LOG: "3/23/93 11:00:03 | Error [158] Requestor not registered :
PCM:" -or- "3/23/93 11:05:03 | Error [158] Requestor not registered : PCM:NETWORK/POSTOFFICE" In ADMIN's Mailbox: "Requestor not registered :
From: NETWORK/POSTOFFICE/USERID" CAUSE loadTOCNode(1, 'cause'); If the NETWORK/POSTOFFICE are a foreign DirSync postoffice, one of the following may cause the error: • The NETWORK/POSTOFFICE was not defined on the directory server using ADMIN:CONFIG:DIR-SYNC:SERVER:REQUESTORS:CREATE. Without this, the directory server does not accept requests from a requestor. • The REQNAME field in the DirSync message has a typo for the NETWORK/POSTOFFICE name or the directory server has a typo defined for the FFAPI gateway postoffice. • The REQNAME field does not contain a NETWORK/POSTOFFICE. For example: REQNAME=PCM: The Directory Synchronization with Foreign Mail Systems Manual does not clearly explain the need for the network and postoffice name for Microsoft Mail Software Development Kit (FFAPI)-based gateways. Other gateways require only an entry containing one of the predefined types. These types are listed in the "Foreign DirSync" manual. APPLIES TO • Microsoft Mail for PC Networks 3.0
Jun 25, 2008 | Audio Players & Recorders
Project Justice for Dreamcast Logo
231 people viewed this question
Top Project Video Game Consoles & Games Experts
James Wishart
Are you a Project Video Game Console and Game Expert? Answer questions, earn points and help others
