Question about IBM ThinkPad R52 Notebook
Keyboard is reacting slow
Hi pals my keypad is reacting slow it needs to press any key for 2 secs. kindly tell how to improve reaction time
  • 103 Answers
Hi
I think you have a sticky key problem. Go to control panel/ accessibilty options/accessibility options and then confirm all the settings with some friend. Fix your settings in the control panel. Especially all the keys like sticky key, togglekey and filter key. Try them out.
Genius Guy
Posted on Oct 16, 2008
  • Hemant Ramyead
    Hemant Ramyead Oct 16, 2008
    If these do not work it could also be due to humidity in your keypad. Try cleaning it out. Without water of course.
I have forgotten my alarm code for my motorhome Sigma S30 The keypads still work but I need the code to reprogramme a more rememberable number
Here are some important informationabout Sigma S30. Programming a New PIN Code:
The standard PIN code can be changed following thesequence below:
i) Type in to the keypad **
ii) Type in to the keypad the "existing PIN code" then *
iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" #
Programming Remote Keys to the System:
Remote keys can be added or removed to/from the systemfollowing the sequence below:
iii) Type in to the keypad 91 * " the number of keys to beused" #
iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all
keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required
to operate the system must be taught during this operation- any key not included will no longer
operate the system.
Full Programming, Diagnostics and Features
This section contains all the information that the dealersuse for programming and diagnosis of
the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried
out using a dealers CP1 programmer.
MK1 Keypad Programming Introduction
It is important the keypad buttons are not pressed tooquickly-
Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should
not be pressed before this confirmation.
It is important the keypad buttons are not pressed tooslowly-
When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will
automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad.
You must wait until the LED stops flashing and then startagain.
All programming functions are entered after typing * andthen the programming PIN code. The programming
PIN code is 17856.
To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid
remote key. (Or keypad using the PIN code)
* 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2
digit function code, then another * and then sometimesoptional parameters as shown in the following tables.
It is important to remember the * key is used to separatethe various parts of the code like this:
* programming PIN code * function code * parameter #. The# key is pressed at the end of all
sequences and is used like the "enter" key on a computer keyboard.
Programming Features On or Off:
Programming
PIN
Function
Code
Switch Code
(where 0=off and 1=on)
Function Default
* 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off)
* 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off)
* 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off)
* 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off)
* 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off)
* 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off)
* 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off)
* 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve
output on wire 4
* 0 (off)
* 17856 * 08 * 0 or * 1 then #
hold-down remote key button =
extends lock pulse
* 0 (off)
* 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off)
Programming Timing Settings:
Programming
PIN
Function
Code
Variable(s) Function Default
* 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec
* 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec
* 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec
* 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two
short pulses)
01 sec
* 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives
two short pulses)
01 sec
* 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec
* 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec
* 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec
* 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve
output time after disarm , on wire 4
(green/red) in seconds
60 sec
Displaying System Diagnostics:
The dashboard LED displays the value of settings as anumber of flashes.
Programming
PIN
Function Code Function
* 17856 * 30 then # time elapsed since last trigger (inminutes)
* 17856 * 31 then # as * 30 above - but each flash = 256minutes
* 17856 * 33 then # wire 7 (orange) ignition trigger count
* 17856 * 34 then # wire 1 (blue) -ve door trigger count
* 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount
* 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren
plug)
* 17856 * 37 then # ultrasonic's trigger count
* 17856 * 38 then # last trigger register (see tablebelow)
* 17856 * 39 then # reset all above trigger counts to 0(zero)
Setting Up Pre-set Programs:
Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a
starting point for further tailoring:
* 17856 * 80 # everything off, lock and unlock pulses 1second.
* 17856 * 81 # as for * 80 above, with auto-rearm on.
* 17856 * 82 # as for * 80 above, with auto-arm on.
* 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on.
* 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3. Hope this will help you. Good Luck.
Aug 22, 2011 | GPS
BACKSPACE KEY, ENTER KEY, NOT WORKING!
Hi Janis552,
Thank you for bringing the problem to my attention. Sounds like the the particular keys you mentioned is not working anymore. One way to test the issue is to log to the BIOS menu. Turn off the computer and wait for 10 secs. Turn on the computer and keep on tapping F1 or F2 to go to BIOS menu. Once you are inside the Bios menu test the keys that you mentioned if they will react. If there is no reaction to the keys then the problem is the keyboard itself. You need to repalce the keyboard. You may call Lenovo tehc support at 18774536686
Thanks!
Jul 08, 2011 | Lenovo 3000 N100 Notebook
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Left mouse button is to slow . I need to press the button for more than 1 second before it reacts, I single short click gives no reaction.
    then its time to replace your mouse, there a mechanical problem with the mouse that gives you these problem
    Nov 23, 2009 | HP Wireless Optical Mouse
    How can I enter a soft (2 sec.) pause in a contact number on A766
    1) From the Home screen, go to Start > Contacts
    2) Select the desired phone number
    3) Press the Menu soft key and select Edit.
    4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
    5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
    6) Use the keypad to enter any additional numbers if desired.
    Tip: You can create pauses longer than two seconds by entering multiple pauses.
    Aug 01, 2009 | Samsung Propel A767 Cell Phone
    Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
    NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
    Mar 22, 2009 | HP 2133 Notebook PC
    ACER 5620 Extensa keyboard problem.
    Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
    1. Find and press the "Fn" key.
    2. Find the F11 key there should be in blue letters "NumLk"
    3. Press F11 while holding down the Fn key.
    This should turn off the integrated keypad
    Hope this works ~Kaleb~
    Nov 12, 2008 | Computers & Internet
    Cannon NP 6035
    2 things will cause this.
    1 is a problem with the scanner: brokenn cable, dirty rails, dirty or faulty sensor, faulty scan motor or motor driver.
    The second is much simpler. A stuck key on the keypad will lock the machine. Press every button on the panel to make sure each one makes the usual click sound as it is pressed. Sometimes just pressing the keys will cause it to become unstuck, other times the keyboard must be disassembled to remove the crumb, dirt, debris, etc, interfering with the key.
    Sep 18, 2008 | Office Equipment & Supplies
    Keypad not functioning properly...
    Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
    May 14, 2008 | Acer Computers & Internet
    19 key Numeric keypad with 2 usb ports
    You better consult your hardware manual.
    If there is no manual Try checking your regional language selection in control panel. Check your MS word configuration go to: Tools > Options Check your settings for keyboard or input device.
    Oct 10, 2007 | Targus USB Ultra Mini Keypad Keyboard...
    IBM ThinkPad R52 Notebook Logo
    770 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
