Question about EliteGroup 845GV-M3 Motherboard
Cant install powercolor 9600 pro on EliteGroup 845GV-M3 mobo... Fan will run in agp express slot but hardware not found on boot up (win XP)
  • 4 more comments
  • findads Oct 17, 2008
    thanks for your input, but when I change bios to recognise card on startup I get no signal at all; from the 9600 pro or the onboard card, yet when I plug in Nvidia mx4000 128 Mb card I have no problem. (except its a **** card!) Is there any known compatability issues with ati/ powercolor? any other suggestions would be much appreciated.
    Is there anything else that should be adjusted in BIOS?
  • findads Oct 18, 2008
    Yes, upon removal of the Powercolor I get signal back on Mobo card. The mx4000 is AGP also. Thanks for the link, I went there and registered & am trying to get solution from them also, but if you have any further ideas they are welcome. Your last comment (guess mobo needs AGP card to run at 1.5 volt.....) I dont really understand what that means, can the supply to AGP port be adjusted?
    there is a jumper on the graph card... I believe it will change the AGP level. Do you think that would make any difference? Do you know what setting = what AGP level?
  • findads Oct 19, 2008
    The card is Powercolor 9600 PRO (game FX board series) 256MB 128 BIT AGP 8x. There is no pins/ port etc to plug external power. It is very similar to http://www.directron.com/r96hc3. Except it is 256 (not 128)
  • findads Oct 20, 2008
    Ok, thanks for all your help mike, I really appreciate it.
    President:
  • 2,351 Answers
HI findads,
You need to make a change in your bios. Still have your manual for the 845GV-M3 motherboard?
If not you can download it at this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=465&DetailName=Manual&DetailDesc=845GV-M3%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
You will also need Adobe reader to view the pdf file. Get Adobe for free at: http://www.adobe.com/products/reader/
If you have already installed the 9600 AGP card, please shut down your system. Unplug the power cord from the power supply. Open your case & remove the 9600 AGP card. One must follow an order of sequences’ when changing graphics cards. Once removed, reconnect the power cord to the power supply & boot the system. (It’s ok not to close your case). As the system starts to boot, press the Delete key on your keyboard every two seconds. The main bios menu will load. Read the instruction at the bottom of the menu which will show you how to move about in the bios.
(The mouse does not function while in the bios).
Using the manual to help change a settings.
Go to Advanced Chipset Features page 35, than into Integrated Peripherals, page 37.
Set Init Display First to [AGP]. Save the bios & exit. The system will auto restart. Once your screen goes to black, press & hold the power on / off button on your case until the system shuts off.
Unplug the power cord from the power supply. Install the AGP video card. Make sure it is completely seated & even in the AGP slot. Screw it down. Before closing the case, re-check all internal power connections to every device & all data connections. (Snug fit). Close your case & reconnect the power cord to the PC. Boot your system. You should have display & windows should load.
Install the CD software for the 9600 Pro video card. Restart the PC. Go to power color & check for any driver updates for the 9600 Pro card. http://www.powercolor.com/
Before installing any update from PowerColor check windows for updates.
Everything should work out ok.
Good luck findads!
Questions? Post here.
Mike
Posted on Oct 16, 2008
  • 3 more comments
  • Mike Peluso
    Mike Peluso Oct 17, 2008
    HI findads, now that is odd! When you removed the 9600 AGP card did you get display on your monitor? I have gone through the manual twice. There is only one bios setting as I mentioned which changes the motherboard from using the onboard PCI graphics to AGP express graphics. There are other settings (In the bios) when using the PCI intergrated graphics card. Things like setting total amount of system memory. Once display first is changed to AGP all settings for the intergrated video are ignored by the bios.
    When switching to the AGP express, one only needs to change, Set Init Display First to [AGP].
    You mentioned the onboard & the 9600 do not show display. Yet the mx4000 works. Is the mx4000 a PCI video card or AGP?
    ATI & PowerColor cards are like twins. Take the ATI 9700 Pro card. ATI shows what voltage the card supports.
    http://ati.amd.com/products/radeon9700/r...
    It's my guess your motherboard needs the AGP card to run at 1.5volt.
  • Mike Peluso
    Mike Peluso Oct 18, 2008
    I would not move the jumper on the video card. I would need to see it or see the manual for it.
    Let’s forget about the onboard graphics card for a minute. Please give me the full name of the video card or card's, so I can find a snap shot & possible spec sheet for them.
    Example: "PowerColor 9600 Pro 128MB DDR AGP 4x 8x"?
    See this link: http://www.directron.com/r96hc3.html
    "Jaton - nvidia Geforce MX4000 / Low Profile Support / Dual Vgas /128MB DDR/AGP 8X"?
    As seen here: http://www.antonline.com/p_3DFORCEMX4000...
    To answer your question about 1.5v = voltage. All AGP video cards run at a certain voltage.
    Older AGP cards, 2x speed ran at 3.0 volts. The AGP slot feeds the AGP card, though most had a plug to provide more power to the AGP to run.
    4x & 8x AGP cards normally need an AGP slot to provide the 1.5volt to function. Other motherboards & your current MB lack the proper information needed. The manual normally provides voltage information needed for the AGP card. AGP slots vary, AGP 2X (3.3v), 4X (1.5V), 8X (0.8v)/(1.5v) or Universal AGP 3.0 bus configuration (2X/4X/8X).
    This can get confusing for the average user. Voltage at the AGP slot can not be adjusted. Though some cards require additional power. Some cards use a 4-pin molex plug. This power connector is the same as an IDE power connector. Other cards use a connector that can power a floppy drive.
    Here is a picture of an ATI RADEON 9700 PRO 256 MB AGP card. Scroll down till you see:
    Requirements:
    I can tell this card supports 1.5v because there are two separations at the copper contacts.
    Again there are many AGP 1.5v cards that have three separations.
    After checking the manual again I find you do not need to change the bios to [AGP]. The motherboard will automatically sence the AGP express is in use & boot to it. See note 3 at the bottom of page 19. After checking other cards listed on page 18 in manual. I am sure you need to run a 1.5v compatible AGP card. The video card that does not show up on your monitor is either not compatible or you need additional power from your power supply. There must be a power port on the AGP card to plug into.
    Mike
  • Mike Peluso
  • Mike Peluso
    If you find this helpful please adjust your rating.
  • Mike Peluso
    Mike Peluso Oct 19, 2008
    Considering everything we have gone over there is one item we have not done.
    That is to try the AGP card in another system that uses an AGP card. I have a feeling your PowerColor card is bad. Even though the fan functions. This link shows your PowerColor card:
    http://us.st12.yimg.com/us.st.yimg.com/I...
    This card is 1.5v compatable & it should function correctly on your, EliteGroup 845GV-M3 MB.
    You have nothing to loose by moving the jumper on the card but I advise against it untill you hear from PowerColor. On the other hand if this is a new card, suggest you return it to whom you bought it from. There are many AGP 1.5v cards out there with faster memory.
    This XFX is warranted for life:
    http://www.tigerdirect.com/applications/...
    Mike
Can an EliteGroup 945GCT-M3 run a Geforce 440 GT graphics card?
AS it GEFORCE 440 requires (pci express) PCI-E 2.0 x 16 and your motherboard has 1 x PCI Express x16 slot, so you just need to check your motherboards manual if motherboards pci express is x16 2.0 if so, you can go for a upgrade and run. as I found itcan run nvidia geforce 8 or 9 on fixya.
Jun 24, 2012 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
Hi Just bought a Powercolour HD6850. Placed in slot, connected the 6-pin power cable and fired up my system. New card is not recognised however. Placing the monitor cable in either of the outlets at the...
Try installing the drivers for this card. If that does not work, it could be a problem with DirectX, being that it is a DX11 card while you're running DX9, or it could be defective hardware. Make sure the fan is spinning on the card when you turn on the computer.
Apr 30, 2011 | Power Color PowerColor AX6850 1GBD5-DH...
I installed win xp but the drivers for 845gv-m3 v10 does not work that i download from your site? Please help
btjunkie.org is my resource for all of my XP drivers I answer this question a lot from folks that need drivers. If you can I suggest upgrading anyway to Win 7 they are downloaded mostly for you during the install process which makes it a lot easier these days to fix machines. Less time in any event go to that site make sure that you have U torrent a torrent file down-loader program software. Type in the search box once at the btjunkie site XP drivers you will have thousands of them to download on one disk insert the disk then go to devices seek the drivers needed to be found point the seek to your drivers disk and hopefully it can be had. I never have an issue with drivers using the software downloaded from there site. I hope this assists you. It is also for those of you who read this post to keep your driver files with your purchase when you bought the computer. If this is not the case then you will have to hunt them down.
Jan 15, 2011 | EliteGroup ECS 845GV-M3 (1.0) ATX...
Powercolor x1650 512mb AGP problem
The one you bought is 16x but your MB supports only 8x..................sodeep
Jun 18, 2009 | Power Color 256MB PowerColor ATI RADEON...
Just put together A780GM-A MOBO With dual processor amd and used my harddrive from my old system. It comes up to cmos setup, but it won't boot to windows. It comes up with the screen that ask you if you...
That mean you if you put a hardisk into the mobo but you never format the disk along with the mobo you need to do so. you need to format/install win xp/vista on the hard drive so that it can work with the mobo.
So here is the point, if you have a new mobo, whenever you put hardisk on it, you must format the hardisk with win xp/vista.
Jan 29, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Cant install powercolor 9600 pro on ECS 845gv-m3 mobo
Appreciate the direct "Ask Me".
Background info, a Powercooler 9600 PRO EZ was most probably manufactured by C.P.Technology in Taiwan. I am sorry to say that quality wise, this company is rather low and to my understanding, a lot of their products has to be returned/replaced even new. On the other hand, the old Nvidia MX4000 might have been manufactured by Palit, also in Taiwan but has a better quality control as of the time of production. The MX4000 though only uses 128Mb of memory but runs them at 275/400 (DDR) MHz clock speed compared to the 9600 PRO 200 (400) MHz. The slow memory onto the PowerColor RADEON 9600 PRO EZ 256MB had a really bad effect on its performance.
To your concern, the ECS 845GV-M3 (V1.0) uses AGP Express but should not cause a problem to either the 256 or 128. since it is working with the 128, then it would be safe to say that the 256 is defective. if the 256 will test OK in another motherboard, then it would be a compatibility issue, try setting the CMOS/BIOS to default and see if it will work.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Computers & Internet
ATI 9600 xt problems
Hi, Im guessing that your motherboard has an intergrated video card & you installed the 9600 card into the opened AGP slot on the board. If you would have listed the model number of your motherboard I would't have to guess. What you need to do is enter your bios & make a change so your bios loads the AGP slot & not the intergrated video card. How to get into your bios? As soon as you turn on the Pc press the Delete key every two seconds. If your system fails to load the bios than you will need to try some of the others F keys. Let the PC finish loading. Re-start the PC. As it starts up try the F1 key every two seconds. Continue in this manner using these other F keys untill your system boots into the bios. F2, F10 or F12. One will work for you. Once in the bios use your manual if you have one. You are looking for Video display. You want the bios to load the AGP slot first, this will disable the intergrated video automatically. Your Pc will now see your 9600 video card & you will be able to load it's software. If the 9600 uses ATI's software you should update the Radeon software by going to ATI/AMD & update your video software with the latest drivers. Click the link I have posted below to upgrade your Radeon 9600XT card. Good idea to save the link.
http://ati.amd.com/support/driver.html
Fill in the needed information to get to your driver software.
If your using Win XP Pro or Home click here:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Feb 19, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
P4VMM2 - what graphic card to use?
Any current brand/model of an AGP video card would work with this motherboard (NVidia or ATI). The only limiting factor would be how much you would want to spend for it.
Not a preference but an observation dito sa tin, mas matagal buhay ng ATI compared sa NVidia.
Hope this be of some help/idea. Pls post back how things turned up or should need additional information.
Jan 10, 2008 | EliteGroup P4VMM2 Motherboard
Mother board bios update
From datasheet on Intel 82865GV: > The 82865GV does not support AGP. ECS use selfmade "AGP-express" port, which isn`t "real" AGP. It is answer that this motherboard need to support videoadapters by BIOS. Recommendation - do not use this motherboard (and other on i865GV chipset) with "external" graphic.
Aug 03, 2007 | EliteGroup 865G-M Deluxe (865GMV50)...
EliteGroup 845GV-M3 Motherboard Logo
453 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
