Dell Latitude D620 Notebook Logo
Posted on Oct 16, 2008
Dell 620 Smart Card Reader
Can not get active client middleware to recognize the integrated smart card reader on D620.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 01, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
14676
Points
16
Start menu, right click my computer, manage, device manager, check if the base system device or unknown device has a yellow question mark next to it, if so download the correct driver from dell.coms support/downloads section, yuo will need to select your model and operating system.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1721
Points
I have installed usb sdhc card reader drivers from the dell site
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1787
Points
Does anyone know where I can find deep technical information about smart cards?. I'm doing a report for the company I'm working for.
smart card
Why did smart card interface failed to install?
ur smart card has no problem, problem have with ur system's USB Drivers , reinstall or update ur system's usb driver ur smart card will easily connect
1helpful
Gemplus usb key smart card reader 0 troubleshooting
Gemplus has now become Gemalto.
Go to the 'Gemalto' website and download the latest drivers for your system. Installation instructions will be on their website for the drivers.
1helpful
Installing internal dell m90 smart card reader
You have to take apart a good portion of the laptop to reach the Smart Card Reader spot. You need to turn off the computer, unplug the AC power and remove the battery first. Make sure that you are grounded to the computer. Then remove your optical drive and the hinge cover. Next you remove the mini-card antennas either from the mini-card or their secure spot, display assembly, the keyboard and the palm rest. Then you can reach the screw for the smart card reader and the place on the motherboard where the smart card reader connects.
The full set of steps and pictures is available from the Dell support site, http://www.dell.com/support/Manuals/us/en/19/product/precision-m90 . See the Workstation Service Manual. The direct link to the English version is ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_precision_mobile/precision-m90_service%20manual_en-us.pdf . There are multiple pages you need to follow.
I hope this helps.
SMART CARD AUTHENTICATION no smart card reader found
I'm only guessing here, but did you set it up for Smart Card Authentication? If so I guess if the card reader hardware fails then so does Authentication unless replaced. Anyway I'm keen to hear the perfect solution for your Laptop problem.
Need software for Gemplus GCR432
Here you can download it http://www.drivermax.com/driver/update/Smart-Card-Reader/Gemplus/VISA-Usb-Smart-Card-Reader-GCR432
Schlumberger Reflex USB v.2 Smart Card Reader Driver
i dont think there is one after XP. gemalto havnt bothered with it. some usb smart card readers were included with some usb keyboards on some pc makers like Dell its possible that the drivers for these might also work for the reflex one you have. but its also likely they will not load. you could try either a dell or hp smart card usb driver. you also have to turn on smart card reading service in the OS. Dell USB Smart Card Reader Keyboard Driver Driver Details Dell UK https://technet.microsoft.com/en-us/library/dd979545(v=ws.10).aspx
Jan 27, 2012 • Cameras
Comment obtenir le cable USB pour transferer les photos de l'appareil vers un ordinateur
Mon Francais et trais mal , mais je comprend votre problem. Le cable est pas nessecaire pour transferer le photo. Le photo etez dans le carte de memoire de type SmartMediaTM CARD dans le appareille. Achter un card-reader specialment pour cette carte. Par example:
http://www.comparestoreprices.co.uk/memory-card-readers/integral-usb-smartmedia-card-reader.asp
Mettre le Smart Media card dans le reader, et le USB dans la computer. Start/My Computer/ D: ou E: clickez dans le folder labas et voila votre photo et la. Copy and Paste bon chance.
2helpful
3answers
Hardware specs for a dell latitude d620
try here for the specs, manuals (including service manual) and drivers for your laptop
http://support.ap.dell.com/support/downloads/driverslist.aspx?c=au&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D620&os=WW1&osl=en&catid=&impid=
be aware that building a laptop the way major companies do is to add all the wiring for all options before it's finally put together so the plugs and sockets are there in case they are required.
please take a moment to rate this solution thanks
robert
1helpful
2answers
Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
