Question about iLO (2 GB) MP3 Player
Write protect My flash is write protect with virus do it . Can you solve this problem for me. can not format can not do anything
    Sergeant:
  • 213 Answers
Go to my computer> properties>hardware > device manager >last one universal bus driver click on it>go to driver and update it
choose only second option when asked
Posted on Oct 17, 2008
When open the PC,suddenly the curser stop working,even if the disk is almost empty,pls give me a tip to solve this problem,thnx..
for me its a virus problem. formatting your pc may take away the problem but if the virus is coming from the other partition you have to conduct a full format
install a license anti virus and don't forget to update it for better virus protection before installing anything else. most of the time viruses came along with the application you install to your computer
i wish this solve your problem
good luck
Sep 24, 2011 | ASUS P5KPL-AM SE Motherboard
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to format write protected pen drive
visit this website for steps:www.techsupportforum.com
Jul 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove write protected in my 8 gb transcend
hi........please check that if there is switch in your pendrive..if present turn it other side..if not than follow this steps... 1. download a software from here http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
2.now fromat your pendrive by this software and than scan it for virus ...
hope this will solve your problem
May 25, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Virus affacted. cannot clean. so i want to format it. Cannot format it saying the disk is right protected. Help me format or clean this USB.
Hello and thank you for using Fixya's services.
You can scan the flash drive with your virus protection. If this doesn't work, then right click on the flash drive, choose properties and uncheck "read only" on the bottom security tab.
This will give you back the admin rights to reformat.
Please let me know if you have any questions.
Nov 10, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb not formating due to write protect
Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
 Best of luck.....
Jul 24, 2009 | Electronics - Others
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Flash drive write protected? can't add files
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Jun 01, 2009 | Kingston 2GB Secure Digital Memory Card
My pen drive got write protected.how to remove that write protected
Solutions:
Update 1:
For that:
May 02, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
