Question about EliteGroup L7VMM2 Motherboard
Hardisk not detected
My pc is not detecting ide hardisk, even i swap the data cable of cdrom from hardisk, yet cdrom is only detected. I have ecs l7vmm2 motherboard attached with 1.6 ghz amd duron, and 2 128 mb pc266 ram, with builtin video. what could be the possible problem and repair for that?
  • jayzone84 Oct 19, 2008
    its still not yet fix, my jumper drive is set to master, its already at primary ide controller and bios enabled, still not working, i think only 2 things which is the source of problem either power supply or motherboard. but its still not sure. when i try to run fdisk it cant detect hardisk so it restart all over, i swap the hardisk from another harddisk, even the power cord. yet still no harddisk found.
    President:
  • 1,901 Answers
Is this the only HD in your system? If so, make sure the jumper on the drive is set to Master. Also make sure you use the Primary IDE controller. Make sure the IDE controller is enabled in the BIOS also.
Posted on Oct 16, 2008
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
By startup fails to see IDE 0 and IDE 2 , says no channel 0 and channel 1. Is it possible that the cmos battery is empty?
Once your powered on the CMOS battery is no longer an issue. If it isn't reading the IDE or SATA channels it could be because they are not set in the BIOS. Check your BIOS setting and double check your cable connections. You also need to make sure, for IDE devices, that one of the drives is set to Master and the other to Slave otherwise they confuse the board and cancel each other out.
Jan 03, 2011 | Asrock P4VM8 Motherboard
I could not hardisk detect on pc when decting hardisk,please boot another disk
Check that the "data" and "power" cables to the disk-drive are fully-connected to the disk-drive.
Check that the "data" cable is fully-connected to the motherboard.
Enter BIOS SETUP, and check that the motherboard has detected the disk-drive.
Otherwise, your disk-drive has "died", and must be replaced.
Aug 01, 2010 | Samsung (SP1203N) 120 GB Hard Drive
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
My Dell Dimension would not Boot when I try to Boot the power light jush flashes if I remove the yellow and black cable from the power surploy you can here it booting but there is no video
hi there,
well,unplug your pc, try to put back cable supply,try to configure your hardisk on cmos/bios set up,if the hardisk have detected by your cpu,refresh your hardisk,disconnect hardisk ide cable from motherboard and put it back.then try to run again.if windows does not
come out,reinstall your windows again on your cd installer you can fix from repair your system.have a nice day
Jul 06, 2009 | Dell Dimension 1100 PC Desktop
Primary IDE master not detected
Hi darchie_1213,
Power off the system & unplug the power cord. Open your PC case. To remove any static build up from your body, touch the metal bottom of the case before touching any internal parts.
It sound like the primary IDE data cable is loose or the power cable to the drive is loose. Try disconnecting both & than re-connect them. If that does not stop the issue, replace the data cable for the primary IDE drive. Click on the link provided. The site will explain IDE connections & the differences between a 40-pin IDE data cable & an 80-pin data cable. (Pictures included & lots of helpful information).
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
Try the above first. If the problem continues the issue could be the hard disk drive.
Mike
Apr 11, 2009 | ASUS P5V800-MX Motherboard
IDE controller not working properly
having done these things get in touch and we will go from there
Nov 01, 2008 | Intel D101GGC Motherboard
EliteGroup L7VMM2 Motherboard Logo
120 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
