Question about JVC TH-C5 System
Lost the cable that connect from the system to the subwoofer
I lost the cable that connect from the system to the subwoofer is there anywhere i can buy another and where can i get it
  • 1 more comment
  • honolulu55 Dec 02, 2008
    i have the cord except i had to move then when i set it up again the cord wont go back in and now its all messed up can it be fixed or do i buy another one cuz i went to bestbuy where i bought it and they didnt have it
    i have the cord except i had to move then when i set it up again thecord wont go back in and now its all messed up can it be fixed or do ibuy another one cuz i went to bestbuy where i bought it and they didnthave it
  • Anonymous Dec 11, 2008
    i know the one walmart sells does not fit the back of the subwoofer. its has more holes than the outlet has. this is not a normal s cable. Can you not order it online from jvc
  • 86 Answers
Any electronics store,Radio Shack,Best Buy, Circuit City... they should have a good selection, if you got a best buy - its more recommended they have Whole selection on Home theater systems.
Posted on Oct 16, 2008
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Hi I have a Philips HTS3450 system but lost the Subwoofer, Is there a way that I can connect the Subwoofer connection to my Panasonic Home theator system to get the sound? Thanks in advance
I'm not sure what you mean by "connecting the Subwoofer connection to my Panasonic Home Theater System"
If you want to watch something on the Philips and send the audio to your Panasonic Home Theater you can buy a VGA to AV Adapter Cable. Just connect it to the back of the Philips HTS3450, get an AV cable (red,white,yellow) and run it to the Panasonic.
I recommend buying it here: http://www.buy.com/retail/product.asp?sku=212966742
Aug 11, 2010 | Philips HTS3450 System
Need the cable to conect my subwoofer for VR-407......HI i recently change to another house, and in the moving i`ve lost the cable that conects the subwoofer, i dont know were to get it. Or how can i make...
You don't identify the subwoofer so we have to guess.
Since it only supports a powered subwoofer I would guess you just need a standard single RCA cable available anywhere hifi cables are sold.
Apr 20, 2010 | Kenwood VR-405 Receiver
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
I lost the cable that connects the subwoofer to the computer and i cannot find a replacement anywhere. Help.
if it's digital you can use a male (35mm) to RCA jak's . or analog use a standard male on male or 35 mm
Jan 13, 2009 | Boston Acoustics BA735 Computer Speakers
Cable lost
A subwoofer cable is simply a single cable with an RCA jack on each end, there is nothing special about it despite what Monster and other manufacturers would like you to believe. You can buy one the length you need or make your own.
Dec 29, 2008 | JVC TH-M505 System
I have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.When i plug everything in and power it up i get a quick 3 second burst of sound and then it stops,but the...
i have a Pioneer HTV-C2 center channel virtual surround speaker system with a powered subwoofer.Lost the cables, can somebody help me, dont know where to get them???......original cable part # are
ADX-7239 this is the system cable A and (rectangle connector)
ADE-7023 this is the subwoofer cable B.....(round connector) 8 pins both
is there any compatible cable....thanx apprecieate ur help!!!
Jun 30, 2008 | Audio Players & Recorders
JVC XV-THC4 Home Theater System
it a 8pin din cable ,,,,I picked up one from a specialty cpu shop in Norcross,Ga
but search ""8pin din cable"" see what you find!!!!
the power cord is extremely common ,you can find that one anywhere ,,,,,most any dvd player ,playstation etc etc etc uses that cord
Sep 17, 2007 | JVC THC4 Home Theater System with 5-Disc...
HK395 Speakers/Subwoofer Cable
Jul 26, 2007 | Dell HK395 Computer Speakers
JVC TH-C5 System Logo
139 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
