Question about IBM (73P0544) Motherboard
Configure bios I want your help to configure bios in my mother board ibm, cause this don't find no hard disc, and cd-rom
  • Cecilia Gracian Dec 22, 2008
    TRIED F2 AND DEL, NEITHER WORKED
  • 52 Answers
To configure bios you should either press f2 or press DEL at the system boot.
Posted on Oct 26, 2008
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
I needed to change the hard disk of my computer. I installed the hard disk and tried to install the operating system which I have been using viz. windows XP pro. I inserted the operating system cd in the...
Hi
first go to the BIOS and check your Hard Disk is detected or not if it is detected then go to the boot section on your BIOS and set CD Room as a first boot device and HDD as a second...
or if your hard disk is not shown in the bios then check your hard disk reconnect power on you hard
disk.. and most important thing don't forget to check jumper setting of you hard disk...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Computers & Internet
MY MOTHER IS IBM 09k9982 011 ATX SO HOW TO 1ST DIVISE CD ROM
login to bios setup then set your first boot to cd room
Jul 13, 2010 | IBM (09N5424) Motherboard
Can't instal xp
You can try and tap on the F8 key when the computer is booting up and see if an optional boot menu pops up and if it does then select the CD-Rom Drive to boot from the CD, and if not then you will have to go into your BIOS setup and change the boot sequence to boot from the CD-Rom Drive first. Also, if you already have windows on the hard drive and you are using a modified boot screen you might get an error when you try to install XP.
Jun 10, 2010 | IBM (25P3294) Motherboard
I am trying to restore an old IBM 2194 Model 18A. It seems to do the test of RAM but the hard drive does not light up (it does start running) and ther is a black screen on the monitor but it does turn the...
If the BIOS battery is a coin size battery 20mm dia.- type CR2032 then the BIOS battery voltage should be 3 volts.
Replace it with a new battery and configure the BIOS with Date and Time etc.
Jan 28, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
I am not sure
Code 5962: An IDE device (other than hard drive) configuration error.
Things to check:
  1. Run configuration
  2. CD-ROM drive
  3. CD-ROM adapter
  4. Zip or other ATAPI device
  5. System board
  6. Riser card
Regards
Jun 23, 2009 | IBM NetVista PC Desktop
Ibm motehboard
update its bios, setup will ask u to select the language during installation, select your desired language and follow the on screen instructions. that's all
May 24, 2008 | Dell Hard Drive Control Board - 6568C...
LG CD Rom Drive CRN-8241B(ABT)
hi Rich24 this is is nichu
first of all check whether the cd rom is connected properly to the hard disc and the mother board.
then follow these steps
in the bios set up
enter into bootable devices
set the first bootable device as -CD Rom
2nd bootable device as -hard disc
this must solve your problem
Oct 14, 2007 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
