Question about HP iPAQ hw6965 Smartphone
Charging indicator stays red
With low battery my ipaq 6965 mobile phone turned off.
When I tried to switch it on by recharging the charging indicator stays red and never turns to green which usually happens when it is fully charged.and while charging the red light even turns off by itself.I haven't seen my phone working for 4 months.
Any help appreciated.
MALLIK
    Sergeant:
  • 213 Answers
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Posted on Oct 16, 2008
My hp ipaq 614 wif is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 23, 2012 | HP iPAQ 614 Business Navigator 2.8-tft...
Why won't my phone turn on?
Usually, the red light indicates that the battery is so low that there isn't enough of a charge to power the phone. Leave it charging for a while, then try again. Alternatively, if it is still a problem, take the battery out, which will reset the phone, then put it back in and recharge. Hopefully, one of those 2 options will help. If not, got to your wireless store for help!
Jan 20, 2012 | Kyocera Zio M6000 Cricket
N 95 After a full recharge says battery Full in the night ,Cell phone seems switch off in Morning but try to open no results only reboot after plugging in to charger
try to change battery first.
some tips :
* proper way of charging your mobile must be turn off
* using your mobile while charging is not recommendable because this is the reason why battery is easily drain and it suddenly turns into low battery level.making a call and player music as well as video is also a factor of making the battery weak while on charge.
* might your phone end to a shorted or shortage mobile because of overcharging the phone...and for sure some of the internal components of the mobile might get damage...
please rate me if this solution helps...you can ask testimonial too... thanks
Jun 02, 2011 | Nokia N95 Cellular Phone
How do i turn off my hp ipaq 6515 off
how can i switch off my hp ipaq 6965
Sep 08, 2010 | HP iPAQ HW6500 Cellular Phone
Iam useing sony ericsson w850i for past 1 year.suddenly one day it was switched off if i seem to turn on it is flashing the red light.and now iam not useing that phone any ideas to turn on my phone back.
from my own experience and idea, I think that flashing light indicates low battery.
This is usually common with Sony ericsson phone, it flashes a red light once battery is low and you want to power is on.
Maybe should test your phone with another battery.
All the best.
Jan 05, 2010 | Sony Ericsson W850i Cellular Phone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Indicating steady red light can not charge
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
May 21, 2009 | i-mate Ultimate 9502 Cell Phone
Sony Ericsson s500i
i think blinking of that red light indicates when ur mobile is running on low battery check ur battery by putting it into another sony ericsson s500i and see if it works
May 26, 2008 | Sony Ericsson S500i Phone
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
May 13, 2008 | HP iPAQ hw6965 Smartphone
MDA problems
Your battery is very very low. The red light is indicating an almost dead battery. In fact, you may have a battery that is too low to charge. Or you may have dead cells in the battery that require you to purchase a replacement. Try my guide to manual battery charging. I have it listed in all of the HTC Wizard (which is actually what type of phone you own) sections. http://www.fixya.com/support/r211784-phone_charge_all_no_lights_fix_here
Oct 04, 2007 | T-Mobile MDA
HP iPAQ hw6965 Smartphone Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
