Question about HP - HP Photosmart 8250 printer
Error 0005dab5 i recently changed the ink (all cartridges) but i have a problem, when i give any command the printer restart and give me the turn off buttom and error 0005DAB5
  • bolerti Nov 02, 2008
    This only occurs when printing photos from the sd chip. The printing stops and the paper is left in the rollers. The Photo Tray light blinks although I was not printing from the tray and all functions lock. I see nothing about the tray to address. Pressing the power button results in that page being ejected and the printer resets itself but does not turn off unless I press the power button again. Once reset I can print a test page from the menu.
    Nick
SOURCE: ink system failure
Just got off the phone to HP and the issue is resolved *phew*. This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
HP were pretty good and were very willing to send out a new printer if the reset didn't work (as the printer is still in warrenty). Hope you get yours sorted too. Rebecca
Posted on Nov 12, 2007
SOURCE: MP150 Error code 4 and 5
Don't use refill cartridges, because it will damage your printer someday. and will cost your parts as brand new. so better use the original ink.
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
yeah !!!
Thank you very much.
Posted on Feb 25, 2008
SOURCE: "ink cannot be correctly detected" error U130
I had the error message U071 and U130. I pressed the stop/reset, OK, the black and color start buttons all at once and the error message just disappeared.
Posted on May 17, 2008
Grubhead
  • 5259 Answers
SOURCE: Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Posted on Apr 12, 2009
I just purchased a Canon Pixma MG6220 and during setup ~> (right after I installed ink cartridges) I received an error code 6C10 ~> telling me to power off printer and restart ~> when it restarts...
I Tried everything,then I had the print head in the middle and turned the printer upside down and shook,out fell a little piece of foam from one of the ink cartridge,now works great.
Oct 12, 2012 | Office Equipment & Supplies
I am receiving a cartridge error on an HP OJ 5510 all-in-one printer. I have tried a black cartridge new cartridge to clear the error without success. The color cartridge seems to be okay. I have...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Sep 22, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer is giving offline error (Printer not responding)
Hi, this offline error also happens to me. Thankfully i have found a couple of solutions for this.
CHECK YOUR PRINTER.
  • Make sure your printer is switched on.
  • Ink cartridges are properly installed.
  • See that the printer is not out of paper.
If you are still getting the "Printer offline error" then there is a chance that there is a communication problem between your printer and the computer. This is managed by the spool service in windows and we need to restart it. To be able to do so, please follow this instructions:
1. Click on the "Start" button and click on "run". 2. In the Run window type "services.msc" as shown below.
A services window will pop up, scroll down and find a service called "Print Spooler" Click on it and two options (restart/stop) will appear on the left top corner as shown below.
Click on the "RESTART" or "STOP" the service, then the printer spooler will restart and the frozen printing will resume. i hope this helps.
Aug 16, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Error 306 can't get printer to work with my mac. It was working just fine until I changed the cartridges and now it gives me an error 306
Error 306 is a communication error and should have nothing to do with the cartridge. Check to make sure the printer is plugged in and restart your computer, and try again.
Jul 25, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
My esp5 all in one printer says there is an error a paper jam but there isnt one please help
1. Take out both the ink cartridges, wait for 5 seconds.
2. Take out the printhead, and close the printer access door
3. Take out the power cable without turning OFF the printer, and wait for 30 seconds.
4. Now connect the printer with the power cable, and turn ON the printer.
5. If the printer is giving an error” printhead missing”, now put the printhead back.
6. Closing of the printer access door brings up error message “missing cartridge.”
7. Insert both the ink cartridges into the printhead.
8. Close the printer access door, and wait until printer gets ready for printing.
9. Give a print command after loading paper in the upper tray.
Best of Luck
Saj
Oct 27, 2009 | Kodak ESP 5 Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Error
Have you changed the ink cartridges recently? A mis-seated new cartridge was sufficient to stop my epson printer working (different model). A check you might run to verify this would be to try to check the ink level from the printer control panel in windows. If the ink cartridge is not seated correctly you will not get an ink level displayed.
Aug 24, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
Printing Error
try changing the ink cartridges.
This may have happened due to low ink levels. Also try reinstalling the printer driver.
If the print cartridges are damaged this problem will pop up. Even static electricity in human hand could damage the print cartridges.
Oct 07, 2007 | HP PSC 2355 All-In-One InkJet Printer
192 people viewed this question
Seeker5211
Seeker5211
