Question about Dacor Kitchen Ranges
Replacing a dacor r v 30 downdraft control panel
How do I get the top of..then what do I do?
  • John Stewart Oct 22, 2008
4 Suggested Answers
SOURCE: dacor downdraft vent
dacor down draft ventilation won't turn on
Posted on Dec 27, 2007
  • 110 Answers
YOU WILL NEED TO CONTACT A AUTHORIZED DACOR DEALER OR PARTS DISTRIBUTOR I SUGGEST CALLING FOX APPLIANCE IN ATLANTA GA OR THE MFG IN BERKLEY ,CA
Posted on May 30, 2008
SOURCE: 30" Viking downdraft
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Posted on Jul 08, 2010
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
Dacor Microwave DMT2420S control panel screen white
It is the CPU/display assembly that has a problem.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
In my professional opinion, there are weaknesses in both the design and manufacturing.
Our proprietary modifications and repairs are designed to not only repair these, but prevent them failing again.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you with disassembly.
Please tell your builder about us.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 21, 2009 | Dacor DMT2420SS Microwave Oven
I have a Dacor downdraft vent RVxx. I find that 2
I just unplugged it again and replugged it. Now it works. Thanks! Renee
Jun 13, 2009 | Dacor Preference RV36 Kitchen Hood
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
May 26, 2008 | Kitchen Ranges
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Call Dacor at 800 793 0093. They'll tell you who has the part.
Dec 03, 2007 | Dacor RV36SS Kitchen Hood
DACOR DOWNDRAFT RV36B PROBLEM
when just the high and low lights are lit, the unit is in childproof mode. try holding down the high and low buttons at the same time until they go out. then if they do, check the response of the other buttons. If this dosen't help, there are really only 2 other options. Most often we see the control board go bad on these (located behind an access panel in the lower right hand corner of the unit below the counter) or the button pad contacts wear out. If the only button that doesn't respond is the up down button, and all the other buttons work fairly easily once its up..then you probably have a bad button pad. If the thing does all sorts of weird things and seem to have a mind of its own, probably a bad control board. the control boards on these fail so often, they re-designed the board to prevent further failures. The button pad is easier to replace and cheaper, so if you have to guess go with that first. good luck!
Jan 01, 2007 | Dacor Prefrence PRV36 Stainless Steel...
Kitchen Ranges Logo
73 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
