Kelvinator split system a/cond
Can the low speed on the fan be droped down lower then the standard factory setting on a kelvinator split system air conditioner, model no. kse70cra.
Please send me picture of 1.5 Kelvinator Remote
Posted on Jun 15, 2009
    Scholar:
  • 121 Answers
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
Unit works fine set at 77 -- if lower to 75 or 73 coils condensate and run down into fan housing and drip out the bottom. i have checked for coils freezing up not the case, I have changed fan speed, c
With the tstat system off and fan in auto the fan still runs? ecm motors have a constant 240 and run by the low voltage. with the stat set properly verify voltage to the motor. if no low voltage only high then the module is likely bad. psc motors run when the speed tap is energized. maybe trace problem back to a bad relay. The 77/75/73 thing doesn't make sense unless it is then running in 2nd stage. Static pressure will increase fan speed and cause lots of issues with the fan pulling water off the coil and missing the pan. I have a piece if plexiglass I use so I can remove the blower door and cover with the glass to see what's happening. The coil is supposed to condensate, possibly slow the fan down in second stage. Check your static, check the subcooling, and also be sure you have the baffle/ shark fin in the coil set the right way for your application (horizontal right/ horizontal left) best wishes!!
Dec 24, 2017 | Celiera Celi 18000 BTU Ductless Mini Split...
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
Shastalaker7
A/C, Contractor
Jun 12, 2011 | Heating & Cooling
Kelvinator split- type room air conditioner not working and has E9 on digital display what is happening
E-9 means high or low pressure. Please service your unit and then check. May be sometime problem would have solved. If not, check fan speed. If less rpm change new capacitor. Thanks.
Dec 27, 2010 | Heating & Cooling
I have a 1.5 hp kelvinator wall mounted air cond.It has three button (cool,fan,and dry)If I want to get the room really cold what is the best button to push
The best button to push for that is the cool button, then turn the thermostat all the way to cold.
The fan button will only move air around and will do no cooling.
The dry button is for dehumidification, in this mode the unit will run a low speed fan over the cooling coil to take the water out of the air.
So for cooling your best option is to push the cool button and crank down the thermostat...
Heatman101
Jan 11, 2010 | Heating & Cooling
Not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
Dec 14, 2009 | Heating & Cooling
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
572 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
