Question about Sibelius Computers & Internet
Cannot find License Server
First of all, we have 2 music room, 15 PC in each room, we are using License server 5.1, in client PC we have version 5.2.5, we have 35 licenses. Here is the problem: This academic year, we upgraded the client PC. in 1 PC we installed everything and we put the image in all PC. when we rename the PC and connect to the domain, once you open the Sibelius 5 its showing the error like "Could not find License Server" and when you click "OK" it will close. I know something like the error is in License Server. Sometimes its opening but only in a few PC. You cannot open in all the PC at the same time. It will gives you the error saying that duplication in the license server. I installed windows XP SP3, but still the same. Any solution for this?
Thanks,
Lorhence
  • Lorhence Oct 16, 2008
    So, you mean I have to make some changes in our T.S. server? but in our server its all working fine.
    Sergeant:
  • 213 Answers
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Posted on Oct 16, 2008
  • shivam raj
    shivam raj Oct 17, 2008
    if it is working fine
    then no problem
    but if the problem again then you have to change T.S. server
How do i connect a client directly to my server?I keep getting an error message sayin i'm using an in store sychronization which is not supportedt by this version. My other client is working perfect. One...
First make sure all stations are on the same version, then uninstall the enterprise server/client services from the appropriate machines. Next, direct connect the client to the server. pcAmerica no longer supports the "enterprise" sync (which is lame) but have switched over to sql replication in the newer versions (which costs $$$). so the only way to do sync w/o redundancy is with direct connect. id also check out faq.pcamerica.com for some help
Nov 02, 2010 | Pc America Restaurant Pro Express
FOr the windows 2008 server standard edition clt 5, is it necessary to purchase client OS?
Anything else already can be a client... If it is NOT a Server, it is a Client, effectively.
Mar 10, 2010 | Microsoft Windows Server 2008 Standard -...
Hello, How can we revoke Temporary TS per Device CALS in Windows server 2008? Thanks.
hi there,
When a terminal server is configured to use Per Device licensing mode, and a client computer or device connects to a terminal server for the first time, the client computer or device is issued a temporary license by default. When a client computer or device connects to a terminal server for the second time, if the Terminal Services license server is activated and enough TS Per Device CALs are available, the license server issues the client computer or device a permanent TS Per Device CAL. If the license server is not activated or does not have any TS Per Device CALs available, the device will continue to use the temporary license. The temporary license is valid for 90 days. A permanent TS Per Device CAL issued by a license server is configured to automatically expire after a random period between 52 and 89 days, at which time the TS Per Device CAL will return to the pool of available TS Per Device CALs on the license server.
In some circumstances, you might want or need to return a TS Per Device CAL that has been issued back to the available pool on the license server before the automatic expiration period has been reached. For example, you might want to do this if the client computer or device is no longer a part of your environment.
In Windows Server 2008 you can revoke a TS Per Device CAL by using the TS Licensing Manager tool.
In Windows Server 2008 you can only revoke a TS Per Device CAL. You cannot revoke a TS Per User CAL.
After you have revoked the TS Per Device CAL, that TS Per Device CAL will be immediately available to be issued to another client computer or device. Revocation is not a substitute for ensuring that you have enough TS Per Device CALs to support your environment.
You can only revoke up to twenty percent of the number of TS Per Device CALs of a particular version installed on your license server. For example, if there are 100 Windows Server 2003 TS Per Device CALs installed on the license server, you can only have 20 of those Windows Server 2003 TS Per Device CALs revoked at any given time. If you also have 200 Windows Server 2008 TS Per Device CALs installed on the license server, you can revoke up to 40 of those Windows Server 2008 TS Per Device CALs in addition to the Windows Server 2003 TS Per Device CALs that you have revoked.
Use the following procedure to revoke a TS Per Device CAL by using TS Licensing Manager.
Membership in the Administrators group, or equivalent, is the minimum required to complete this procedure. Review details about using the appropriate accounts and group memberships at http://go.microsoft.com/fwlink/?LinkId=83477.
To revoke a TS Per Device CAL by using TS Licensing Manager
1. Click Start, point to Administrative Tools, point to Terminal Services, and then click TS Licensing Manager.
2. Expand the node that represents the license server that issued the TS Per Device CAL, and then select the node that represents the version of TS Per Device CAL that was issued. For example, click Windows Server 2008 - Installed TS Per Device CALs.
3. From the list of issued TS Per Device CALs, select the TS Per Device CAL that you want to revoke.
4. On the Action menu, click Revoke TS CAL.
5. To confirm that you want to revoke this TS Per Device CAL, click Yes.
6. If the revocation was successful, a message will appear confirming that the TS Per Device CAL was revoked and telling you how many more TS Per Device CALs of that version you can still revoke.
7. Click OK to close this message. The Status column for the TS Per Device CAL will show a status of Revoked when the TS Licensing Manager display is refreshed.
Hope this helps, good luck, God bless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 04, 2009 | Office Equipment & Supplies
How can i connect client computers to server where clients have no hard disk.How clients can boot and access hard drive of server?
u can connect with ur client through terminal server. for that u've to server 2003. u can see the steps that how to configure terminal server for that u've to go this link:
http://support.microsoft.com/kb/300847
Sep 25, 2009 | Microsoft Windows Xp Home Edition Sp2...
Probs in licensencing
Micorosoft is the only one that can help you with the licensing key.
Check your group policies in the admin settings of your server to see what has been enabled for the clients.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Computers & Internet Logo
915 people viewed this question
Top Sibelius Computers & Internet Experts
Martin Murray
richie46
 Russ Hill
Russ Hill
Are you a Sibelius Computer and Internet Expert? Answer questions, earn points and help others
