Multikey secure multimedia proxy using ARPS-java source code
How to create multikey secure multimedia proxy using ARPS, i need source code for the project.plz send as soon as possible.
  • saran anitha Dec 20, 2008
    sir i have received your solution that to got little idea and i want java source code for the solution please help me.............
    Sergeant:
  • 213 Answers
Because of limited server and network capacities for streaming applications, multimedia proxies are commonly used to cache multimedia objects such that, by accessing nearby proxies, clients can enjoy a smaller start-up latency and receive a better quality-of-service (QoS) guarantee-for example, reduced packet loss and delay jitters for their requests. However, the use of multimedia proxies increases the risk that multimedia data are exposed to unauthorized access by intruders. In this paper, we present a framework for implementing a secure multimedia proxy system for audio and video streaming applications. The framework employs a notion of asymmetric reversible parametric sequence (ARPS) to provide the following security properties: i) data confidentiality during transmission, ii) end-to-end data confidentiality, iii) data confidentiality against proxy intruders, and iv) data confidentiality against member collusion. Our framework is grounded on a multikey RSA technique such that system resilience against attacks is provably strong given standard computability assumptions. One important feature of our proposed scheme is that clients only need to perform a single decryption operation to recover the original data even though the data packets may have been encrypted by multiple proxies along the delivery path. We also propose the use of a set of encryption configuration parameters (ECP) to trade off proxy encryption throughput against the presentation quality of audio/video obtained by unauthorized parties. Implementation results show that we can simultaneously achieve high encryption throughput and extremely low video quality (in terms of peak signal-to-noise ratio and visual quality of decoded video frames) for unauthorized access.
Posted on Oct 16, 2008
How to use hack? i want to hack of my stalker facebook
First learn Java, Java Script, Pearl, Basic, and Pro is a good start for computing languages. Then become familiar with using CMD based prompts usually through a UNIX based system. Once familiar with using CMD style prompts rooted on a UNIX/Linux based system Id check up on your security and at least proxy yourself through a known source and start doing some packet sniffing. If you dont know what a packet is or how to recieve anon info then well...
PS Hacking = very illegal and facebook has hired some very talented programmers making this highly unlikely
Pro Tip: Learn what a Keylogger is or a Trojan this might help
May 09, 2011 | Computers & Internet
I want h.264 video encoding and decoding source code in java
visit the below link help to download the source code
www.sourcecodeonline.com/list?q=h264_encoding
Dec 19, 2009 | Opcode Wiley H.264 and MPEG-4 Video...
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Java source code for MPEG-4 H-264
hai solve the problem. the problem is i am doing project in proxy services. the problem is i need services like encryption,decryption and compress video.. i want source code for that
Mar 25, 2009 | Opcode Wiley H.264 and MPEG-4 Video...
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
Problem in java
This is how to create notepad application in java:
http://www.dreamincode.net/forums/showtopic66176.htm
Also, you can take a look to this one and download free source codes:
http://forums.targetlife.com/showthread.php?t=259
Enjoy it! Good luck
Mar 04, 2009 | Sun Java Programming Language (cdj-275)
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Dec 23, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Creating biodata form in java script
i want to create a biodata for every citizen and non-citizens in nigeria. how can i make it a dream come true.
Sep 08, 2008 | Computers & Internet
To create window using java codes
What you need is FrameDemo by Java which allows you to create Frames (or windows) using Java. Get it here:
http://java.sun.com/docs/books/tutorial/uiswing/components/frame.html
May 07, 2008 | Computers & Internet
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
