Question about Kenmore 44102 Front Load Washer
Smelly washer, smelly clothes; sitting water under the drum
Old smelly water sits under the drum and does not drain. it is under the rubber. i soak it up with a towel, but this does not solve the problem.
what can i do to solve the problem of sitting water under the drum?
  • hilewe Oct 16, 2008
    the washer is only a couple of years old. the washer is spinning and draining the water from the clothes very nicely. it is the water under the drum that is the problem. i will check your suggestions though! thank you!
  • rfoster4 Oct 29, 2008
    We have the same smelly problem, and are wondering if adding TSP (trisodium phosphate) solution to mix with water residue in the tub under the drum,between washes, might control mildew growth without corroding the inside of the washer?
  • 750 Answers
Hello hilewe
Welcome
You said, old smelly water sits under the drum and does not drain. it is under the rubber. i soak it up with a towel, but this does not solve the problem. what can you do to solve the problem of sitting water under the drum?
How old is your washer?
This drainage problem may be caused by a number of situations
First check these things listed below!
1. Water in washer does not drain or .
2. Drain hose is kinked or clogged.
3. Clean and straighten the drain hose.
4.Drains slowly. Maximum standpipe height is 8' (2.4 m).
Is the drain at the same level as the machine .
Or does the water need top be pumped up higher to an existing high drain as if from a basement?
If none of these things are the case, you can try one other thing before calling service!
Unplug the washer for 10 minutes and then after these 10 minutes see if the system has reset!
In some electronic washers this may be all it takes to reboot the system.
If you tried all these things first and they did not remedy the situation, Then you may need hands on service.
Here is an article I just read that you may find interesting
If the washer is old it will not pay you to repair the
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Posted on Oct 16, 2008
  • Neil Golan
    Neil Golan Oct 16, 2008
    Dear hilewe,
    You just told me it is the water that is under the drum that will not empty.
    In most washing machines , all the water will never completely empty!
    As long as you do not see any water in the tub after the wash cycle is complete .
    Between the inner tub and the wash tub with you clean clothes in it, there will be some water left!!!!
    If it smells then you need to run bleach and hot water in it once a week ans leave the door open when it is not in use.
    A lot of front load washer brands have this problem.
    And for some reason it is an excepted norm in the industry!
    Unless there is something else that I am missing or not understanding about your problem?
How do i get to the main drain and pump on a kenmore elite front load washer
You will need a few towels. There is a cartridge like filter located on the front lo2er left corner of all current front load washers for cl3aning purposes. Remove or open the access panel plate and begin unscrewing the cartridge. After about 3 full turns it will begin to leak water. If you have a elevation base with a drawer place towels inside there to soak up water that leaks out. Once drained unscrew and pull straight out to clean the lower filter. There is another place to clean out just inside the drum on the front just under and behind the door seal
Jan 03, 2015 | Kenmore 4.0 cu. ft. Steam Front-Load...
Water pooling in the Gas cap compartment. Is there a drain hole somewhere?
Yes.
It's probably gummed up. That happens sometimes, especially if the car has been sitting and the rubber adheres to itself around the hole.
Soak up the water with paper towels, get a strong light and look for the drain hole.
Sometimes you can just work it open with your finger.
I hope this helps.
Regards
Richard
Nov 04, 2010 | 1993 Jaguar XJ6
Washer not draining
sorry about this problem,we get this alot your drain pump is clogged,so try this take cloths out and see if you can scoop out water.Now put rooto-roter drain opener in drum and let it sit for about 1-2hrs.Now run on heavy-duty by itself it may have to go through 2 cycles,to clear out clogg.See the drain pump is real small,so dog hair,strings,or pieces of rubber from throw rugs well clog pump.So first try this.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Smelly clothes
Maytag had a big problem with the rubber boot in the front of the washer.They redesigned it to drain better so water would not remain in the bottom and get moldy smelling.Open the door and look down in the boot with a flashlight.Make sure if there are drain holes in the bottom that they are clear and not clogged with soape or lint.Put a couple of old towels in the machine and a little soap and twice as much clorine bleach as normal and run a cycle.It should help.It is also good to leave the door opened between washes if possible.
Jun 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
We went to tumble dry towels but when going back to the machine the drum was full of water and the towels soaking wet! Now we can't get rid of the water in the drum. We even tried to run a program to drain...
If you can, lay the drain outlet hose down to floor level, and let the water run into a bucket or similar.
Then check the filter, which should be located at the bottom front right of washer behind drop down flap.
Remove and clean by unscrewing it anti-clockwise.
Hope this helps.
Jan 20, 2010 | Zanussi WJD1257W Front Load Washer
Smelly washer
The disgusting smell is from using too much detergent, using softener or from using only cold water for washing.
The area of buildup is just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this area: http://www.youtube.com/watch?v=Ua6OJPn0-fU
The added bulk of the laundry will raise the water level to include the "splash area" intermittent pausing to soak is also a good tip in extreme cases.
Oct 01, 2009 | LG WM1812C Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Pool of water in the drum if I let the clothes sit.
this is a very comon problem, not really witht the machine though. well i guess it is now.
you have debris / change / other stuff.... lodged into the pump
remove the lower access panel, disconnect power, there is a screw out portion on the pump, nail catcher. remove it and catch all water that comes out with a towl. unscrew it slowly to allow the water to slowly come out, or it will make a mess.
the clamp that secures the drain boot to the tub, loosten it and remove. use a large towl to catch the watter that comes out.
remove the spring clamp from the drain hose and remove the drain hose. again use a large towl to catch water. disconnect pump power supply and remove the screws that secure it to the washer, remove pump.
clear all debris from the pump and check to see if anything has damaged any impellars in the pump. do this with your finger.
clean out the rubber boot as well.
reasemble in reverse order.
before the access panel is put back, start the machine and visually check for leaks. if it leaks reset the rubber and clamp where it is leaking.
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smelly drum
is the water draining ok and is washer spining ok?,if this problem is recent a small kids sock or something could be sitting somewhere beside element or in drain pipework,first you could try a 90degree wash with nothing in drum,this will get rid of any undissolved detergent/powder which can stink sometimes if low temp washes are used alot
May 06, 2009 | Indesit W 123 Front Load Washer
Kenmore 44102 Front Load Washer Logo
1,135 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
