I have a philip 42 in plasma tv that i bought 3 years ago and yesterday the image went from perfect to speckles and red lines... only about a 5 in horizontal section in the middle of screen is still okay... audio good...
    Scholar:
  • 86 Answers
This is a problem that I've seen a million times with HP TV's that use LG panels. The problem had to do with the controller board that sends the signal to the video sustain boards. To rule out any signal interference that maybe causing this if I'm wrong, bring up the OSD and try a DVD that is connected to a different input. If they are effected too, then it is has nothing to do with the incoming cable/satellite signal and the TV would require service.
Posted on Oct 16, 2008
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Snow
There is a fault in the main processor that is causing noise. The set will have to be serviced. The tech will probably try the main video processing board to start.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Lg42px52 speckling.
The speckling is caused by the CTRL board. The firmware needs to be updated. Unfortunately LG does not provide a media slot for downloaded upgrades. You must order an install the factory updated CTRL board located between the power and the Y sustain boards.
Nov 24, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
