Hi im michael i have a old sony projection screen 10 years old or more. i believe its a trinitron.the picture comes on for awhile then goes out and comes back on just a minute later
    Scholar:
  • 86 Answers
Hi Michael,
If you were to watch a DVD using a different input than the cable/satellite input, does the image also fade in and out? When the image disappears, are you able to view the TV's onscreen menu or does it disappear too? When the image comes back, does it look fine and is the brightness the same?
Posted on Oct 16, 2008
Hi...I'm thinking about buying a 2 year old Sony KV32Fs-120, is this a good tv and are there maintenance costs involved in having a tv like this? Thanks, Nancy.
The Sony TV'S are one of the best sets you can by on the market, the Trinitron picture is world famous when it comes to picture and quality. Since it is two years old makes it a good buy, maintenance costs are low compared to most televisions.
Jan 09, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
I havn't lost color, my standby light flashes 5 times.
crt starting to show its age--a screen control adj--located on the flyback-- may hold it off for awhile good luck )
Jul 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Trinitron
Probaly a solder connection on your chassis. look closely around the fly back, horizontal driver transformer and the verticle and horizontal yoke connections
Jan 16, 2008 | Televison & Video
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Help with sony trinitron problem
Are you serious? You have used that television... in particular that CRT well beyond its predictable lifetime.  Congratulations.  Those are early symptoms of CRT failure.  Your screen may turn green very soon also.  It will occur any moment now.  It is not cost-effective to repair.  Welcome to the next generation.  You will be amazed and delighted with LCD, plasma or DLP technology. existencebeyondperception@msn.com
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
