Question about HP Compaq dx5150 PC Desktop
CPU not powering up
I cleaned my computer and now when I plug it in, I get a red blinking light. It blinks 3 times waits a few seconds then blinks 3 times over and over. It won't power up at all. HELPPPPP! What have I done? How can I fix this?
Thanks,
Peggy
Am format my pc ( HP dx5150SFF) after my installation net work not working , i want to install net work divce how to install that
Posted on Oct 19, 2010
  • 781 Answers
Peggy
1. I would first try to find out if everything is properly plugged in place inside your pc. make sure everything is properly seated
note: BEFORE you get your pretty hands inside the case make sure you ground yourself by touching the power supply before teaching any other components, failure to do this you're risking to damage other componets like memory, or the motherboard.
2. if you did 1 but still the system would not power up, you're problem is likely to be your power supply dying on you. I would suggest to replace your power supply and test.
also check this documentation on troubleshooting power supply issues:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=bph06788
hope it helps.. and post back with your findings.
Posted on Oct 16, 2008
  • 128 Answers
Check for loose video card or ram. try to remove them and insert them back again
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
Sep 04, 2011 | Sony Playstation 3 (PS3) Console
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
Playstation 3 power supply switch off red light blinking on
its not the power supply. your cpu needs to be reflowed
May 31, 2010 | Sony PlayStation 3 40GB System
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
HP Compaq dx5150 PC Desktop Logo
286 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
