Question about HP Pavilion 523n (P9851AR#ABA) PC Desktop
How to install ram into my pc
I just opened my pc casing. But I do not know where to put my ram "Card" Please help!!!
  • 749 Answers
How to install ram into my pc - 140423e.gif your new ram goes into the long slots marked DDR DImm socket 1 & 2. If you are using odd sizes , make sure the larger chip is in socket one.
Posted on Oct 16, 2008
  • 36 Answers
Hi Gmworley,
Since it will take too much room to explain to you how to install a ram memory card, I give you these links:
http://www.build-your-own-computer-tips.com/install-ram.html a "how to" step by step text based
http://www.youtube.com/watch?v=SiFIgSQOY7g a video from YouTube in which it is showing how to install ram memory.
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
How to install ram
Please shut the pc and;
remove all cables.
Open the case and locate the RAM slots on your motherboard. If u are still finding difficulties refer to your manual.
Thanks
May 31, 2011 | HP Compaq Presario SR1502HM PC Desktop
My emachine W3623 starts with three beeps, and runs but nothing comes on the monitor
Open CPU, remove RAM and put it back, If you have Grapic card then remove that and put it back, then reset the BIOS by removing the CMOS battery for 1 minite or more and put it back. and connect all cables, etc etc and power on the PC. best of LUck
Jan 19, 2011 | eMachines W3623 PC Desktop
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci...
you need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Beeping
Un-installing and reinstalling the Memory Cards (RAM) from their slots may solve your problem. If they didn't installed properly that happens.
And please check the memory card (RAM) whether they are faulty or not. If there is faulty one, replace it with the new Memory Card. (It beeps if it is faulty or didn't installed properly when you power on the PC.)
Before opening the case please turn off the computer, unplug it from the electrical outlet, then touch the metal casing to eliminate any static charge. Refer to the owner's manual if necessary to determine how to open your particular PC case.
You can find the instructions on how to install PC Memory by clicking THIS LINK.
Hope this helps.
Waiting your comments.
May 24, 2010 | MPC Computers MPC NetFRAME 3600 (NET-774)...
No signal to monitor. no beeps at start up. fans running. new video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
check your RAM (random access memory) m sure your ram is not working
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Mar 26, 2010 | E-Machines eMachines Desktop PC
I want to install 1GB of memory. I need step by step directions
Remove side of PC (left hand as you look from front) locate memory slots, make sure retaining clips are open, insert memory (correct way up) with firm pressure but do not force. Retaining clips will automatically click home. Replace side of PC.
Sep 07, 2009 | Gateway 310 XL (310XLSP) PC Desktop
After i install the new motherboard, and i hit the power button, the screen monitor is not on and my heard the long beep sound from my motherboard. i check all the wire is ok but i dont know what wrong?...
You may need to try a few steps here,
1. Switch of you pc and open up you pc cover.
2. Pull out the memory (RAM) from the slot by pressing down the clipsfrom each edge, be gentle will you push down the clips from each side.Remember how it was seated when u pull out.
3. After that, put re-seat back the RAM back to the slot by pressing each edges in, firmly but not with excessive power.
4.Try to switch on the pc after you re-seated the RAM. If no success, youhv to repeat the procedure again, but this time clean the RAM's contactwith a cloth and contact cleaner, then re-seat it back and try again.
*here's the instruction with diagram to show you how to do it.
and video as well
5.If still no sign of success, you might have to unplug other cards, suchas your video card, and re-seat them back, then try again.
6. Worst case scenario, disassemble your motherboard and test it without fixing in the chasis by fising only your power supply, RAM, Video Card, Keyboard, and see if it works.
Good luck mate, comment here to let me know the progress or any success.
Do remember to rate my solution.. thanks (^_^)
Jan 13, 2009 | Intel Motherboard
Can I install any ram memorie cards that will fit my Dell gx260
The memory has to be the same type that is in your PC. Not necessarily the same manufacturer.
Your PC came with PC2700 DDR memory Dimms.
If you have DDR memory sticks from your other PC, then it may work.
Just make sure you unplug the PC and touch the metal case before you pick up and install the memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | Dell OptiPlex GX260 PC Desktop
HP Pavilion 523n (P9851AR#ABA) PC Desktop Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
