Question about Epson Stylus Photo R220 InkJet Printer
PRINTING PROBLEM blank paper print
I have download a new driver from support center .but same problem.
  • ANKITA665 Oct 16, 2008
    I have use this solution .no any efect for this problem.I have reset my printer to SSC .but same problem .I think head was not heated or miss pulse volt.what I do please help me.
  • Anonymous Oct 16, 2008
    123
    Sergeant:
  • 352 Answers
Hi ankita, how are you?
Let's accentuate the positive, we reasonably that it's not a software problem and we now have the latest drivers installed. So, we'll move to the next possible solution, resolution through process of elimination. Take out ink cartridges and close cover and run a print job, see if the wizard comes up and informs you there are no ink cartridges installed>reinstall ink cartridges when prompted>press continue/next or done>print test page. Write me back and let me know if the was the fix. If not, we will continue, there are several other avenues left to us try. Good Luck...
Sincerely,
anaanymous
Posted on Oct 16, 2008
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
Paper keeps feeding thru w/o printing. Prints a couple of lines jumbled (not what's on screen), throws it out and takes more paper.
Try uninstall the printer drivers and download then install the latest version. This blank paper printing with random "symbols" are caused by incompatible drivers.
Jun 23, 2009 | HP DeskJet 940c InkJet Printer
Printer says it is printing, but paper is blank
This sounds like a driver issue.  Go to the following link and download new drivers, based on your Operating system (XP or Vista, etc).
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441240&lc=en&cc=us&dlc=en〈=en&cc=us&submit=Go%20»
Then go delete your printer from the list, and install the driver you download above.  Reboot your computer and that should fix it.  When you have the wrong printer driver, your computer doesn't send the correct instructions to the printer to print a document.  So, you end up with blank pages or sometimes pages filled with random symbols.
May 02, 2009 | HP Photosmart 2575 All-In-One Printer,...
Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
Please help me, my epson inkjet all in one printing just blank blank blank
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Print is not centered on paper
There are two possible culprits for this problem.
1. The wrong driver is being used for your printer.
2. The paper thinks it is printing to different sized paper than it actually is.
To solve the first case:
Verify that the correct driver is being used. Go to the Control Panel (Start, Settings, Control Panel) and open up the Printers and Faxes component by double-clicking on it.
Right-click on your printer and go to Properties.
A new window will pop-up. Go to the Advanced tab and verify next to where it says 'Driver' that it lists your model of printer.
To solve the second case:
Exactly as you did above, under the Advanced tab, click on the 'Printing Defaults' button.
Then click on the Paper/Quality tab on the new window.
Under the Paper/Quality tab click on the 'Advanced' button.
A new window will pop-up. Where it says Paper/output, expand it (click the plus) to list Paper size. Change Paper size to match the size of the paper you are printing (Letter is the default 8.5" x 11").
Nov 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printing problem
download the drivers and install it
Apr 11, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
