Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
WHERE IS THE WATER FILTER ON A AMANA SXD20NPW?
We just bought a used Amana side by side and we can't get the water to work.
I read a few of the answers on here w/the same type of problem...different models. I am unable to locate the water filter to see if that's the problem. It's not up in the right hand side like most feedback was suggesting.
I can't find much information anywhere on this particular model.
We don't have a users manual and I'm unable to locate any diagrams on the net.
  • springer22 Oct 16, 2008
    Thank you for the info. It seems that this model isn't/wasn't very popular because there's not much info on it. I wonder if this particular model doesn't have a filter? Is that possible? Thanks so much for trying! ;)
    President:
  • 1,901 Answers
Good news and bad news. Here is a link for the manual:
http://shop.amana.com/assets/pdfs/literature/ARF9233.PDF
However, it is poor quality, and really doesn't give much hint where the filter is, or even if it has one. There is no mention of a filter anywhere. Sorry.
Posted on Oct 16, 2008
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Nov 14, 2015 | Amana Refrigerators
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
Sep 04, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Mar 22, 2010 | Amana Refrigerators
Water dispenser not working
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
My Amana refrigerator has water and ice on the outside door. The ice works fine but I am not getting any water. I have replaced the water filter. Can you tell me what the problem is?
Did you check to make sure you have water going into the filter? Sometimes, the tiny hole used in the flow valve gets clogged at the source. Shut the valve and reopen it.
Feb 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Dirty ice
Did you change the water filter recently? If so, you may have some air in the lines which can be purged with a few minutes of dispensing water through the front.
Nov 02, 2007 | Amana ARS9265B Side by Side Refrigerator
Amana ACD2234HRS replacement water filter
Don, I have a manufacturers part number of 67003591, you might be able to cross reference that. Straight from the manual..Catriver.
Jun 20, 2007 | Amana ACD2234HRS Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
145 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
