Question about Philips DVP5960/37
The spin motor doesn't turn spin the disc
So i read the solution #1 in the thread that Philips DVP5960 doesn't read discs. Mine was the same with "LOADING" to "No Disc" problem. I followed the instructions to listen to the spin motor and noticed it doesn't make continuous spinning sound but a start-stop noise was coming from the player. Researched online for a bit and found video instructions on how to open the unit up and clean the laser lens. That's where I could see the motor was not spinning the disc. Is there a easy way to replace that?
    Master:
  • Philips Master
  • 515 Answers
Yes you can replace your lens also your lens is not working so you have to change
the spin motor doesn't turn spin the disc - images-ozq1nix2gcz4ps2max21qnuh-3-0.jpg
Posted on May 18, 2017
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
  • 476 Answers
SOURCE: No Disc message
Turn off the power.
Open the lid and gently push the laser mechanism to the outermost point of the slot.
Power on and try a disc again.
Also try cleaning the laser lens with a mild foam cleaner and cotton swap. Leave to dry and re-try a disc.
If neither work, then the laser is probably faulty. If the unit will play CDs but not DVDs, then this is a good sign of a faulty laser.
Posted on Mar 17, 2008
SOURCE: I put a disk in and it just keeps loading...
The problem is in the motor replace the laser motor...
Posted on Oct 14, 2008
  • 289 Answers
SOURCE: loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Posted on Feb 07, 2009
watcher26
  • 141 Answers
SOURCE: dvd player not reading new DVD
probably needs a new belt they do wear out and loosen up over time
Posted on Feb 16, 2010
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc inserts and ejects with no problems but once inserted, the disc will not spin. Laser mechanism thumps back and forth trying to read disc. Play indicator light blinks on a 50/50 cycle.
Hi tiro079,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Movies that i have watched before on a philips DVD plkayer no longer play, it says, 'no disk'
No disc error can be a DIY like the following steps.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope it may help you.
Have a nice day.
Thanks for using fixya.
JDVillanueva
Feb 01, 2011 | Philips Televison & Video
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Doesn,t read and start disc
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Oct 08, 2009 | Toshiba Televison & Video
Reads no disk
((((NO DISK))))
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Apr 13, 2009 | Philips DVP5960
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Jun 20, 2007 | Polaroid PDM-1058 Portable DVD Player
I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Mar 27, 2007 | Philips DVP5140 DVD Player
Philips DVP5960/37 Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
