Question about Memorex MKS5001 Shelf System
Cd tray not staying closed
When I put in a cd in my Memorex MKS5001 player the tray will not stay closed to play the cd, it just opens back up. I do not see any foreign object in the track of tray that might be keeping it from staying close. How can I tell if the laser / cd reader is working?
  • Satex Oct 16, 2008
    Thanks Electech1,
    I had tried that before and it did not work but this time it did. What could have cause my problem with the tray not staying close even if it didn't have a cd in it. I want to try to prevent this from happening again. It seemed like the open / close button was out of sync.
    My family and I really enjoy our Karakoe player.
    Again thanks and God Bless you
  • 905 Answers
Gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Posted on Oct 16, 2008
  • jason Oct 16, 2008
    the door closes but NOT strong enough to LIFT the LASER MECHANISM which the cd sets on when spinning. this could be the cause of a slipping belt or weakening motor
    And your welcome! god bless you!
I want to know why the tray on my axis9 cd player won't stay closed and play the cd
There is a kill switch that is hit by the tray when fully closed, could be faulty or a wire off
Apr 16, 2014 | Audio Players & Recorders
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
Numark Axis 8-Screen says CLOSE, but does not recognize CD
either your set does not recognize the cd or your lens need to be replaced the age of your set has lot to play if it is old satrt shopping for a new set.anyhow have a tech look at your set.a look on the wire ribonthat leads from the body of the lens the pc board will not hurt probably it is damage.good luck.
Apr 10, 2009 | Nu Mark Numark Axis9 Table Top CD Player -...
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
3rq8 (Triarcuate)
Mar 31, 2009 | Sony CDP-C265 CD Player
check if the power hubs on the back of the back of the drive are hooked up right if they are un hook and hook back up while your pc is off
Mar 13, 2009 | LG GSA-H55N DVD-RAM Burner
3-disk cd tray will open & then immediately close
I would suggest using Servisol Video 40 spray to clean any contacts inside the machine.
Mar 26, 2017 | Memorex MKS5001 Shelf System
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Cd player keeps opening with cd in it
Some small item would appear to be obstructing complete closure
With the drawer open take a good look in side.
Also near the  open button you  should see a small pin hole[sometime on the back of the unit]
 This is the emergency eject device in case you get a jam and is operated with the end of a paper clip.
give it a poke with the drawer open  then again closed
See what happens
Oct 20, 2007 | Memorex MKS5001 Shelf System
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Jun 04, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Memorex MKS5001 Shelf System Logo
392 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
