Question about Sony Handycam DCR-SR40 Camcorder
Will not power on with battery
My camera only works when it is plugged in to AC even with a new battery it will not come on. I tried removing the battery for 30sec did not work then I removed it for a day to no avail I even reset the unit still did not work. After a couple of days I plugged the battery to it and it came on for a second and went off. It works just fine plugged to AC power. Help
  • jrscruggs1 Jan 08, 2009
    Battery was new and it worked on a friends camera. How can I get a power circuit and a schematic for this camera.
  • Anonymous Jan 08, 2009
    you think he is going to give you the power circuit schematic or help after you rated his help like that ?
  • 905 Answers
The battery is dead or that power circut has a problem, but make sure you have a goo battery
Posted on Oct 16, 2008
Lenovo Y550 has been sitting without being used for many months. I tried to power up today. It starts, the disk drive symbol flashes for a second or two, and then it stops. I've tried removing the...
If it works with the AC cord plugged in and not on battery, then you have a dead battery. Even when plugging in the battery it's going to try and charge the battery and THEN provide the computer with power. Get a new battery.
Oct 25, 2013 | Lenovo Y550 Notebook
Averatec 3700 notebook is charged but will not power on, nothing happens when power button is pushed even when power cord is plugged in
Try to remove the battery and turn the computer on with only the AC adapter connected. If it works then the battery is failing. If it does not there is something wrong with the motherboard or the AC adapter. hopefully it is just the AC adapter. Try to borrow an AC adapter from a friend or anybody else. Make sure that the current and power rating is exactly the same. Or else you might end up with a burned laptop. It the known working AC adapter works, then it is your charger. Buy a new one.
Jul 04, 2011 | Battery Technology Battery Averatec 3700...
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Sony Mavica MVC-CD400 will not operate under battery power.
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 31, 2009 | Sony Mavica MVC-CD400 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Lense does not close
sir, ur camera lens mechanically stucked or gears problum ,this is repairable
Apr 12, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
M527
my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
thanks
Feb 25, 2008 | HP Photosmart M527 Digital Camera
Power problem
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Jan 03, 2008 | JVC GZ-MG130U Camcorder
Sony Handycam  DCR-SR40 Camcorder Logo
102 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
