Question about Whirlpool Duet GHW9150P Front Load Washer
Code f11, whirlpool duet washing machine
I know to look for the cable harness, but how do I open the machine up to find the cable?
    Novelist:
    Champion:
  • 261 Answers
You want to remove six screws left right and center on the back for the top panel and for the kick panel below the door. There is a box on the left bottom for motor control unit and another on top. First make sure all connections top and bottom are fully into there slots. We need to unplug the machine and do some measurements for the motor and then to check for voltage. There is a plug for power on the motor we need to unplug. You will see there is five wires, three go to the motor and two loop around to a sensor plug on front of the motor. The top three that go to the motor is our concern.The wires on a schematic are labeled U, V and W meaning nothing on color as they reference points on the mcu where they plug into. Ok using the three that go to the motor from where the harness unplugs from the motor we will label them 1, 2 and 3. Using an ohm meter measure from 1 to 2, 1 to 3 and 2 to 3. Ok so far? Good I hope you found ohms around 6 or 7 on each,if not replace the motor, problem solved. If this is ok we will plug in our wires and the machine. start a cycle and measure the pink wires that plug in to the mcu for 120 volts ac. If this passes then there is two solutions. One is the wire harness and two is the mcu which is around 260 bucks.
Please write back if you have any questions!!!
Posted on Oct 16, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    I have an F11 code on my kenmore front load washing machine
    After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
    Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
    F11 and/or dl code on a whirlpool duet front load washer
    F11 is:
    Serial Communication Error
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Check for:
    Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
    Check the above link for a detailed article about the f11 error code.
    Courtesy:JSrock
    Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F11 Code Showing
    F11 is:
    Check for:
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    Courtesy:JSrock
    Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool ghw9150pwo f11 error code
    f11 Serial Communication Error
    * Check Wire Harness connectors to the MCU, the motor, and Central
    Control Unit (CCU)
    * Check the Drive system for any worn or failed components
    * Check MCU
    * Check CCU
    * Check Motor
    Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool Duet ModelGHW9150PW0 Starts out to do the wASh but the quits after pouring in some water. A signal, F11 comes up and I sometimes have a problem opening the door to get out the wash
    F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Potential Causes
    • Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
    • Check the Drive system for any worn or failed components
    • Check MCU
    • Check CCU
    • Check Motor
    Replace failed component.
    Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Older whirlpool duet washer has error F11
    F11 is a serial communication error between the central control unit and the motor control unit.
    Unplug the machine and open the panels.
    Unplug and re-plug all wire connectors from the ccu to the mcu.
    Inspect all wires and harnesses for a bad wire.
    Could be bad components; ccu or mcu or motor
    Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F11
    these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
    Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR F11 (Whirlpool Duet GHW9300)
    Hi there this is as it reads for your fault code F11
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check MCU
    • Check CCU
    • Check Motor
    Feb 10, 2009 | Whirlpool GHW9300 Duet Washer
    Whirlpool Duet GHW9150P Front Load Problem
    Need to call a tech, this could be a couple of problemd, either a control board or harness( communication code)
    Oct 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    271 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
