Question about JBL GTO 301.1 Car Audio Amplifier
Deck speakers i wanted to connect my deck speakers to my gto amplifier but how?do i need crossover?or can i used cross over for a 1 channel amplifier?
    Sergeant:
    Champion:
  • 341 Answers
An active crossover is needed if you plan to do a 2.1 or 4.1 or 5.1 setup.
Check if you have a subwoofer output from your head unit (most later models have). If there is, you might not need an active crossover anymore, but it depends on how you like the sound quality of the separations (low, mid, high). Please note the speaker polarities too.
Posted on Oct 17, 2008
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Have two front ,two rear speakers, and two tens that i want to hook to my stereo. How do i do it and get the maximum sound?
If the Sony amp (I'm not familiar with that one) has its own crossover and subwoofer output, use that, and set your crossover point for what sounds best to you. Honestly, it is best to have a SEPARATE two-channel amplifier & crossover for the 10" subs. Whatever you do, make sure you use a large capacitor (2 Farad or more) at the power input of the amplifier for the subs. This will help prevent blown fuses. (It is also a good idea to use at least a 1 Farad capacitor at the power input of the amplifier for the other four speakers.)
May 11, 2015 | Sony XPLOD XM-554ZR 600 WATT AMP XM554ZRRB
How to hook up alpine 3653?
Instructions
    • 1 Determine the distance between the system amplifier and the 2-way crossover. Cut this with the wire cutters. Strip 1/2 inch of insulation from the amplifier end of both speaker wires. Loosen the amplifier speaker screws with the appropriate screwdriver. Insert the bare wires under the terminals strips. The speaker wire with the writing or molded ridge is usually used as the positive wire. Tighten the wires down with the screwdriver.
    • 2 Route the wires within the vehicle, avoiding potential hazards such as floors, seatbelt areas, and anywhere where small stressing or abrasion may occur. This usually means under side trim or tucked within the dash. Secure any loose speaker wire with zip ties every 4 inches.
    • 3 Remove 1/2 inch of insulation from the crossover end of the wires. Locate the section of the speaker terminals labeled "INPUT" or "AMP." Insert the wires leading from the amplifier under this strip, following the same polarity used at the amplifier. Screw these down with the appropriate screwdriver.
    • 4 Cut lengths of wire to connect from the crossover to the woofer and tweeters. Strip 1/2 inch of insulation from both ends of the wires. Crimp a 16 gauge insulated connector onto the tweeter end of the speaker wire leading from the crossover. Insert the wires under the loosened screws labeled "TW" or "TWEETER." Tighten these back down to secure.
    • 5 Strip 1/4 inch of insulation from the wire pigtail leading to the tweeter. Insert this into the other end of the insulated connector, and crimp it securely. Repeat for both tweeters.
    • 6 Crimp a 16 gauge female spade terminal on the ends of the wires leading to the individual woofers. Slide these over the appropriate terminals on the woofer, again following the same polarity observed at the amplifier. Insert the crossover end of the wires into the "WF" or "WOOFER" terminal on the 2-way crossover. Tighten them back down to secure.
Read more: http://www.ehow.com/how_7175673_hook-up-alpine-2_way-crossovers.html#ixzz32AMgzu8S
May 19, 2014 | Alpine 3653 2-channel Active Dividing...
I have a true sunfire sub and an onkyo 703 that has an rca connection for the sub. My question is do I connect my side channel polk 65's directly to the sub in jacks or directly to the reciever? If
The input jacks on the subwoofer panel are for connection of satellite speakers to it's crossover. The outputs are for the crossed over signal input to your receiver or amplifier, as there will be no amplification or channel processing from the subwoofer connection. It's only an optional crossover that may have a sonic advantage over the crossover in your receiver.
What you also can do is connect the speakers directly to the 703 and set the crossover frequency on it.
Dec 07, 2011 | Sunfire True Sub MK II Subwoofer
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
I need to know how to wire this amp up!
The B+ terminal on the amp goes to the Positive battery terminal with a fuse inline probably at least 60amp for this amp. The GND terminal of the amp goes directly to the chassis of the vehicle (metal) and try to keep the ground 18" or under. The REM terminal of the amp goes to the remote turn on wire from your deck, usually the BLUE wire. Some decks have 2 one for an amp one for a electric antenna. Dont hook it to the power antenna wire or your amp will only work when the radio is on. Won't work with the cd player. Hook the left and right inputs (rca) to your source unit (deck). Hook your speakers to the left and right channels of the amp with the correct polarity (+) (-) . Set the cross over on the amp HP-AP-LP for what ever application you are using it for like subs or components. There is a frequency adjustment for the crossover on the opposite side of the amp. This should be set in accordance with your crossover selector and speaker requirements. The punch bass knob should only be used with a subwoofer application. The left and right gain turn up or down the gains of the amp. (power output) These are set depending on the output voltage of your preouts (RCA) on your deck. A small flat head screw driver can be used. Set them between 1/2 and 3/4 if you dont know but make sure they are the same. Your ready to go. Hope this helps.....
Sep 26, 2009 | Rockford Fosgate Punch 500a2 Car Audio...
I have my amplifier connected to my dj system only one speaker of the bass works wich is channel 1 channel 2 does not work and fault button keeps on blinking red?
The XTI 2k has lots of DSP options built into the front panel. If it's your intent to run the amp in bridge mono for subs be sure than you have all settings set correct for the DSP, it's very possible that channel 2 will render in-active.
This also applies in the case if you wanted to run your subs in stereo and the internal settings are set for bridged mono.
Another possibility would be if the DSP was set with a crossover. If you put a cross-over point (Low Pass Filter) on the high side of the sub, if becomes the High Pass Filter of Channel 2. Audio would pass if there was no other filter sets, but would not if you were using a crossover and then hitting the subs.
Sep 11, 2009 | Crown XTi 2000 2-Channel Amplifier
Clarion APA5240 5 channel Amp
try this it has worked for me in the past,..Contact Clarion by e-mail .Tell them your a student and learning electronics and in need of installation ,owners manual..ask if they can help and mail you info you need.Or try this link ..Its for a APA5241 could be very similar..http://www.clarion.com/us/en/MungoBlobs/720/1016/APA5241.pdf
Dec 14, 2007 | Car Audio & Video
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
JBL GTO 301.1 Car Audio Amplifier Logo
87 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
