Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My problem is blades won't disengage.
I have an old Craftsman 42inch machine that refuses to disengage the blades; in other words, the blades keep spinning, even though the blades have been put in the disengaged position. What needs to be replaced?
  • 3 more comments
  • Dennis Dietrich Oct 24, 2008
    I have 15 .5 hpin MA and have same problem. Also,
    Deck lift lever onlycan bring it all the way up or all the way down.
  • johnball Nov 12, 2008
    I have the same problem. There is a cable that engages the belt (or in this case disengages, so will not run). If that cable breaks (or in my case, separates from where it is connected to bottom of frame) the blade will not shut off. This has been irritating and somewhat dangerous but I consoled myself "at least it's not the reverse situation, where I could not cut the grass!"
    Check the cable to see if it's broken or detached.
  • masterafe9 Mar 07, 2009
    blades will not disengage while the engine is running. I replaced the cable thinking that perhaps it was defective but no joy. If I shut it down and re-start the blades aren't turning. the interlock switch seems to be working as you cannot start it with the handle in the up position, or engaged.?????????? Oh lthis is a Craftsman 17.5 42' deck bought new in 2003.
  • richardawhit Mar 14, 2009
    I have the same problem? Does anyone have a fix for this????
  • rluhmann119 Mar 15, 2009
    I also have this same problem. The cable that "engages" the blades moves a pulley to put pressure on the drive belt. When the lever is moved to disengage the pulley does not return to the original position. It almost appears that there should be a spring to pull the pulley back, but I do not see one. Hopefully someone can come up with a solution for this. It seems to be a common problem.
Have you tried the safety switches?
Posted on Oct 16, 2008
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Blades wont disengage completely
The lever has worn out....thus it is not locking up immediately when fully disengaged. You'll need to trace down the lever right down to the blade mechanism and then you'll notice a fork shaped part that shows signs of wear....very common on craftsman riding mowers.
Dec 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why dose the blades keep turning when mower is disengaged
If the machine has a manual blade engagment, there is normally a small brake block that presses against the upper blade pulleys to slow and stop them, these may need replacing, if not then the drive belt may be dragging in the pulleys
Dec 10, 2012 | Craftsman Garden
Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
Oct 21, 2012 | Craftsman Garden
Craftsman riding lawnmower won't bag grass
A very common problem since mowers were made noise compliant, to collect grass you need draught, this is produced by putting a large wing on the ends of the blades and having a high engine speed, unfortunatly large wings and high engine speeds mean high noise, so today the wings are very small and the engine revs low, this leads to low draught and grass blockage, you need to keep the under side of the deck clean and free from old grass clippings, make sure the machine is fitted with collection blades, not mulch blades, i cannot tell you to increase the engine revs, however if for some unknow reason the engine were to start reving higher it would help.
Oct 13, 2012 | Craftsman Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
917 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
