Question about Konica Minolta magicolor 2300DL Laser Printer
Black line on left side only
Pulled out drum kit to clear paper jam, no just get black line
    Scholar:
  • 173 Answers
Drum kit? ok you might have to repull it and look for more paper stuck somewhere blocking your toners.
Posted on Nov 10, 2008
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
Asked me a paper was jam
You didnt wrote where it is the paper jam.
Here are few common jams:
  1. if the paper jams in fuser unit, do/check next:clean the paper delivery rollers ( when you open left door its two roller on axis beneath the drum ), check the sensor flapper beneath the drum unit if its worn out you need to replace it, does the paper comes out like bent in the roll? open fresh pack of the paper and try again it could be moisture fault.
  2. the paper stucks in pickup section, clean the paper pickup, feed and separation roller, to do that remove paper drawer and you will be able to see the rollers on left inner side.Open the lower leftside door and check the paper senzor in the middle.You can apply some wd40 on spring of flapper or on left side bushing.
  3. dadf jam, check for any paper leftovers and clean the paper pickup and feed rollers
Hope that helps!
Sep 07, 2010 | Canon iR 2016i Black and White Copier
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Black lettering on drum and is transferred to printed document. Also paper jams continually and sounds as if it is tearing when it exits the machine.
Stripper Blade
■ Drum Maintenance Kit
■ Preheater
■ Electronics Module
■ Drum Assembly
Check for and remove any media, jammed
paper, or debris found in the exit path.
Did this correct the problem?
Clean the Drum Maintenance Kit wiper blade
or replace the kit.
Check the exit area, exit frame, Preheater,
Drum Maintenance Kit, Printhead, and
Stripper Blade for anything touching the
Drum.
2. Reseat any component interfering or
touching the Drum.
3. Clean the Stripper Blade.
Oct 13, 2009 | Xerox Phaser 8400 Laser Printer
CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Aug 28, 2009 | Sharp Office Equipment & Supplies
Solid black line at the left side of paper after reset the drum
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
May 18, 2009 | Brother HL-2070N Laser Printer
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
Apr 05, 2009 | Brother HL-2040 Laser Printer
Black mark on printed copies
Remove the black drum and see if see the line on the drum that you see on the paper---if it is replace the drum unit.. Good Luck
Aug 26, 2008 | Ricoh CL4000DN Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
85 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
