Question about RCA P52937 52" Rear Projection Television
Rca big screen
When i plug in the tv all it does is beeps and will not come on
    Scholar:
  • 86 Answers
Definitely try a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this doesn't help, the TV will likely require service for the mainboard. Since you are hearing a beep, the power supply must be trying to turn turn on but if the mainboard is shot, this is usually the outcome, good luck.
Posted on Oct 16, 2008
My big screen won't turn on, but it's plugged in
That model is famous for having capacitor issue and bad flybacks both items are all on the deflection board. You can get replacement deflection boards for the RCA ITC222A TV( which is what your model is) from www.tvrepairworld.com they also include instructions how to remove the old board.
May 25, 2010 | RCA HD52W59 HDTV Projection Television
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
My RCA big screen tv sound shuts off
This could be several different problems. You could have loose solder joints, bad capacitors, or the aodio ouput IC could be getting hot andf failing and needs to be replaced.
Jan 10, 2010 | RCA P61310 TV
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Tv turned off and started beeping noise
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Jul 20, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
RCA P52937 52" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
