Question about HP Computers & Internet
When I install microsoft 2000 it stalls and doen's complete its installment. "error 1904. Module C:Windows/system32/MSRCLR40.DLL failed to register H RESULT- 2147024703
  • mrs Elu Oct 16, 2008
    My computer is lodged with Windows Vista not XP. Will have any effect if I try to solve this problem with Vista and & it's not XP?
  • 781 Answers
I think you're facing this problem, check out this kb article from ms, it has your syntom and possible solutions.. I hope it helps:
http://support.microsoft.com/kb/279223
Posted on Oct 16, 2008
  • Francisco Cortes
    Francisco Cortes Oct 16, 2008
    now that you mention you have vista.. you may want to think twice about using office 2000 on your vista system as technically what you're trying to do can create a lot of issues (and you're witnessing one) http://forums.techguy.org/business-appli... but on the other hand there's a possibility that it could work, in fact ms indicated that you could run office 2000 in vista http://support.microsoft.com/kb/932087 but they also advise there is not support if any problems were to arise, so try the following but don't forget to back up your data first and create a system restore before you try anything... and again, you may want to get office 2003 as it won't give you much issues (if any at all) when working with vista.
    you can try the solutions on this kb:
    I would try http://support.microsoft.com/kb/237294/ (I noted below some of the steps with link to instructions on what steps to follow in windows vista as it may be different)
    1. click ignore and see if office 2000 works, if not
    2.I would try to do the installation in safe mode:
    http://windowshelp.microsoft.com/Windows...
    3. try to register the file manually (use at your own risk)
    http://www.ehow.com/how_2056399_manually... if not
    4.(use at your own risk) You need to first copy MSREPL40.DLL from a working system running Windows 2000, XP or vista into the C:\Windows\System32 directory on your vista system. Then try reinstalling Office 2000....
    try that and post back if any problems
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
Tip
Nokia Software Updater
Dear updaters, Many of you received the following message when updating their phones "Internal module error". When installing Nokia Software Updater (NSU), very frequently the Microsoft XML4 DLL silent installation crashes. This issue can be fixed by manually registering DLL. Go to Start > Run > enter "regsvr32 C:\WINNT\system32\msxml4.dll" > OK > OK. I hope this helps most of you suffering from this issue.
on Jun 21, 2007 | Nokia N95 Cellular Phone
Hello; i am trying to install my hp sanjet G2710 and i find this error: Errr 1904.Module C:\Program Files\HP\Digital Imaging\bin\hpqcxs08.dll failed to register. HRESULT -2147467259. I need your...
This problem can occur when one of the following conditions is true:
  • The file is not installed correctly.
  • The file is corrupted.
  • Other programs, including memory-resident and anti-virus programs, are running and using any version of the file.
Register the File Manually loadTOCNode(2, 'workaround'); To register a specific file again in the registry, while you are working in Microsoft Windows, follow these steps:
  1. Click Start and then click Run.
  2. In the Open box, type the following command, and then click OK RegSvr32 filenamewhere filename is the name of the file specified in Error 1904.
You should receive a message that the file is now correctly registered. If this doesn't fix your problem then go to http://support.microsoft.com/kb/237294 for further options.
Hope that this helps!
HelpDeskMan
Please rate this and/or leave a comment. Thank you
May 24, 2011 | Computers & Internet
How do I find and install a missing file from windows?
  1. Download and install DirectX 9 here.
  2. After install of DirectX 9, restart your computer in safe mode.
  3. Next, delete d3d8thk.dll from the c:/winnt/system32 folder.
  4. Then copy this d3d8thk.dll (originally d3d8thk.w2k) to "c:/winnt/system32/d3d8thk.dll" and restart.
Jul 13, 2010 | Microsoft Windows 2000 Professional for PC
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
When installing MC9 on my Vista machine I get the following "Error 1904.Module C:Program Files (x86)MasterCook 9ProgramMCWrap.dll failed to register. HRESULT -2147220473. Contact your support personnel."
Are you installing as administrator?
you could try:
Start->run
and type in the following line
regsvr32 "C:Program Files (x86)MasterCook 9ProgramMCWrap.dll"
or wherever the .dll path was
then try reinsalling.
When I installed it, I right clicked on the install file, and clicked RUN AS ADMINISTRATOR.
Try reading this:
mc6help.tripod.com/mastercook_and_vista.htm
Sep 17, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
2. Backup the old version of the DLL file.
3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
Microsoft Money 2007 shuts down after opening
Hi Drdata889,
If you haven't already been to Microsoft support, then follow the instructions below:
This issue may occur if any of the following conditions is true:
  • The installation of the System Pack was canceled.
  • You did not let Microsoft Internet Explorer to install.
  • If third-party software un-registers a very important Microsoft Money component. Currently, SnapStream Personal Video Station (PVS) software and Cellar! software may cause this issue.
To resolve:
Click Start, click Run, type regsvr32 "c:\windows\system32\msxml3.dll" in the Open box, and then press ENTER.
Note On Microsoft Windows 2000-based computers, type regsvr32 "c:\winnt\system32\msxml3.dll" in the Open box.
Note If you receive the "LoadLibrary(msxml3.dll) failed - The specified module could not be found" error message, follow these steps:
  1. Visit the following Microsoft Web site: http://download.microsoft.com/download/xml/SP/3.20/w9x2kmexp/en-us/msxml3sp2cab.exe (http://download.microsoft.com/download/xml/sp/3.20/w9x2kmexp/en-us/msxml3sp2cab.exe)
  2. Click Open, and then click Yes to accept the License Agreement.
  3. Click Browse, click Desktop, and then click OK two times.
  4. On the desktop, double-click the msxml3.cab file, right-click the msxml3.dll file, and then click Extract.
  5. In the Select a Destination dialog box, click the C:\WINDOWS\System32 folder, and then click Extract.
    Note On a Windows 2000-based computer, click the C:\Winnt\System32 folder.
  6. Click Start, click Run, type regsvr32 msxml3.dll in the Open box, and then press ENTER.
Note In the unlikely event that these steps do not resolve the issue, repeat step 6 three times. Every time, substitute Msxml3.dll in step 6 with the following files:
  • Msxml3a.dll
  • Msxml3r.dll
  • Msxmlr.dll
Download and install the latest version of MDAC loadTOCNode(2, 'resolution'); To upgrade to latest version of the Microsoft Data Access Components, follow these steps:
  1. Download and install the latest version of MDAC. To do this, visit the following MSDN Web site: http://msdn.microsoft.com/data/Default.aspx (http://msdn.microsoft.com/data/Default.aspx)
  2. Install Money.
If you still experience this issue, and you are running Microsoft Money 2002, Money 2003, or Money 2004 use the following additional methods.
Reinstall the Microsoft Money System Pack loadTOCNode(2, 'resolution');
  1. Insert the Microsoft Money installation CD into the CD drive or the DVD drive. Hold down SHIFT to prevent the installation screen from appearing.
  2. Open the installation file. To do this in Windows Vista, click Start
    , type D:\syspack.msi in the Start Search box, and then press ENTER.
    To open the installation file in Microsoft Windows XP and earlier versions, click Start, click Run, and then type D:\syspack.msi in the Open box. In this example, D:\ is the drive letter of the CD drive.
  3. Click OK.
  4. Follow the prompts for the installation process.
If the previous steps do not help, see the "Remove and reinstall the Money System Pack" section.
Remove and reinstall the Money System Pack loadTOCNode(2, 'resolution'); Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Locate Microsoft Money System Pack in the list of installed programs. To locate Microsoft Money System Pack in the list of installed programs in Windows Vista, open the Programs and Features item in Control Panel. To do this, click Start
    , type appwiz.cpl in the Start Search box, and then press ENTER.
    To locate Microsoft Money System Pack in the list of installed programs in Windows XP, click Start, click Run, type appwiz.cpl, and then click OK.
  2. In Windows Vista, click Microsoft Money System Pack, and then click Uninstall.
    In Windows XP and earlier versions, click Microsoft Money System Pack, and then click Remove.
  3. Follow the steps for the removal process.
  4. Repeat the steps in the "Reinstall the Microsoft Money System Pack" section.
Hope this is of some use :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Microsoft Money 2007 Home & Business for...
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
