Question about Brother GX-6750 Typewriter
Print hammer not in alignment with daisy wheel and it wont print .is there an adjusment i can make?
I have turned the typewriter on and off and it still is not printing the correct letters.
Posted on Oct 27, 2008
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
Can a IBM wheelriter 6 repair when the G andH will not work
Replace the Daisy wheel cartridge, pull back on the small red top lever and it should rotate the print hammer back exposing the Daisy wheel cartridge, lift out and replace with new one, push the print hammer back forward till it latches and captures the new daisywheel. Turn unit on and let it initialize, try typing, it should be OK. Examine old daisy wheel you will find the G and H segments are probably missing.
Nov 21, 2014 | IBM Wheelwriter 6 Typewriter
The keys typed are not the letters coming up
The SX 4000 is a "Daisy Wheel" printer. A plastic Wheel with the letters embossed on them spin via the input of the keyboard. I would suggest that your Daisy Wheel mhas slipped its index, presenting a offset letter., or the wheel is on inproper, but I do not see how it could happen, short of forcing it on. You may have to buy another Daisy Wheel, if that one is broken at the hub. See:
Dec 14, 2010 | Brother SX-4000 Typewriter
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Print Unit/Daisy Wheel
Most likely the problem is the print hammer. Our service techs see this all the time. Not a cheap repair.
Apr 16, 2008 | Office Equipment & Supplies
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Print Wheel Drive Gear is out of Position
Power up the machine, the "V" groove of the hammer should be center aligned with the "." petal If not 1 remove the ribbon bracket 2 loosen screw of the daisy wheel (element) motor it has locktite on it , slide the motor up or down in its slot until the hammer and petal are aligned. If you cannot correct it this waydue to a lack of travel it becomes a more complicated job may need a typewriter repair man.
Aug 02, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother GX-6750 Typewriter Logo
120 people viewed this question
James Cagle
James Cagle
Jim Keysor
