Question about Amana Heating & Cooling
I have a Amana air command 80 sse central air unit. The unit is comprised of a big fan unit outside, and a unit in my garage. The big fan stays on even though I turn the thermostat off. Do you know what the problem is?
    Scholar:
  • 57 Answers
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Posted on Oct 18, 2008
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Feb 07, 2018 | Amana Heating & Cooling
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
My Amana Air Command 80 SSE IIQ Gas Furnace started up for a few seconds the shut down with no indicator light. I went up and switched disconnect off and on, then checked all connections and fuse on...
Have you cleaned your flame sensor? Take a piece of emery cloth or a piece of light sand paper and sand it a little. It is located in the burner section and it is usually to the left side of the unit and it looks like a L. Hope this helps.
Feb 13, 2012 | Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
Amana central air conditioner unit rce60a2a.fan not spinning.thermostat fine and breakers on.buzzing noise on outside unit.any reset buttons or any advice?thanks, ryan
I would say the Capacitor outside has failed and the bussizng would be the contactor trying to start the unit. If you are able to pull the capacitor and go pick one up at an electric motor place then that would be the cheapest way and they could test it first
Aug 20, 2010 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
No AC air flow Amana 80 SSE
hi! the problem is the fan motor or supply not sufficient.
Sep 08, 2009 | Heating & Cooling
Amana Air Command 80 blower won't come on
Sounds like fan relay or fan motor possibly capacitor. Call a service tech for free estimate on repair. that wasy you know upfront your cost.Rus
Jun 25, 2009 | Heating & Cooling
Heating & Cooling Logo
420 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
