Question about GE JE1540 Microwave Oven
Je 1540 gw 001
  1. no heat. noisy
  • Jesse Moses Oct 16, 2008
    I have a Whirlpool AVM 516 microwave oven, it starts alright but will not heat. In the heating cycle I hear a jarring sound. The timer works okay.
1540 no turn no heat
There is a fuse and it may be some other things.But if you don't feel good about doing this kind of repair, I would have it serviced.
Jun 18, 2014 | GE Spacemaker JVM1540 Microwave Oven
What is the dimension for ge microwave model #JE 1640WA 001
For model JE1640WA001 , the spec sheet is located here.
In case you still don't have it, the owner's manual is here.
Jul 08, 2011 | GE JE1640WA/GA Microwave Oven
Cooked food is not getting heated in my microwave oven. Model no-LG-MH-4048 Gw Please help, I will really appreciate 4 ur quick and helpfull assistance.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jun 16, 2010 | LG LTM9000 Microwave Oven
My jvm 1540 will not heat. any advice?
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
May 31, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
We have a GE microwave model # JE 18600 SB 001 installed with a trim kit that stopped working. Can it be replaced with GE model # JEB 1860 SMSS?
You can download GE owner's manuals and installation instructions here. You can download for both models and compare the two.
Or you can ask GE Customer Support. Contact info is here.
But your oven may be pretty simple to fix yourself or with help from a friend.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit and symptoms) for free DIY help and information.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
This "Nuker-oven" (GE Microwave Oven, Model JE 2800 001) is plugged in to a working electrical outlet, but no light, no fan, no keypad, no timer, no noise, and, of course, no heat. Might there be a simple...
fuse located under the cover. pull the four side screws, 7 or so back screws, slide cover back about an inch or so then lift off. fuse holder is located on top, about 5.00 to replace (had to buy whole pack.
May 16, 2009 | General Electric Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM130 001 Over Range Microwave does not heat
It's probably the high voltage rectifier diode or magnetron.
The magnetron will have a guarantee lasting about 5-9 years, so if it might be covered, contact GE at
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
Also, there should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Dec 08, 2007 | Microwave Ovens
Microwave Ovens Logo
185 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
