Question about HP Computers & Internet
Connecting the paqrallel ata hard disk to the mother board
  • 781 Answers
Cpenny29 explained properly what you need to do.. I just thought you may also want to watch a video about it... to illustrate:
http://www.youtube.com/watch?v=vnEga6ga5hM
I hope it helps too
Posted on Oct 16, 2008
  • 128 Answers
Connect the flat ribbon cable with a red stripe on one side to the harddisk with the red stripe side going to pin 1 and the other end to the IDE slot 1 of the motherboard. take note of the red stripe side to pin 1. set the jumper of your hard disk to master if you are only using 1 hard disk
Toshiba equium m40x
this may caused by hard disk problem. first remove (disconnect) hard disk. then try to enter bios setup. if the problem persist, find a jumper clip named 'bios reset' in mother board near front panel connectors. the default jumper position is 1and 2. now change the clip into 2and3 - power on - wait 5 seconds - power off - reset jumper to 1and2- thats all connect hard disk- check again the bios setting.
Dec 12, 2013 | Computers & Internet
Pulled the cord from the dvd to the mother board in error. which jack to I plug it back to?
If it is a SATA drive connect it to Secondary ATA connector or if it is IDE Connect it to IDE connector
Oct 01, 2013 | Acer Aspire X3400 PC Desktop
I want to get a new internal hard drive but I,m not sure of the hard drive interface type. The specs say Serial ATA 300. The drives I am looking at say SATA?
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
Jan 15, 2011 | Dell OptiPlex GX260 PC Desktop
When started system says invald disk replace the disk,and then press any key
First of all check whether there is any CD in the Drive. If your system is configured with CD as first boot device, instead of Hard disk and there is non bootable disk in the CD tray this could happen. If you find a CD in the tray and removing it gets your computer to boot normaly, then change the first boot device to Hard disk in the BIOS. If this is not the case, check the power and IDE cable into the hard disk for any loose connection. Check the IDE cable at the hard disk end as well as the mother board side. If this also alright, you may want to check the hard disk for probable fault or corrupted operating system.
Feb 08, 2010 | HP Compaq Presario SR1110NX PC Desktop
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
I have problem in installation of windows xp in my new seagate 500gb 16mb sata hard disk before this i had 80gb samsung ata hard disk and i have supphire mother board pe-a9rs482m pure element please reply...
you will need to slip stream the sata motherboard drivers ( from the motherboard manufacturers website ) into the operating system disc and to do this you can use nlite
http://www.nliteos.com/
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Apr 18, 2009 | Computers & Internet
Drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Feb 06, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
