Question about Canon PIXMA MP600 all-In-One InkJet Printer
Compatibility of Ink cartidge.
I have inserted the fine Black Ink Cartidge No 40 by replacing the old one.The colour cartidgeNo 41 was found not empty and not replaced.Printing is not done with the comments on the screen " Black Cartidge can not be recognised Ink not Compatible with printer". How to solve the problem of printing?
  • ksbasuray Oct 16, 2008
    Not going for any agreement right now.
    My printer is MP160 where Black cartidge no 40 and colour cartidgeno 41 are used. As a new cartige has been inserted there may be a problem in the machine.Thank you for your suggestion.
  • 1,572 Answers
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Posted on Oct 16, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Printer is stuck with empty ink cartridge after inserting a new one, How do you do a factory reset?
there are 4 cartidge in the printer , and usualy when getting empty , message will tell you empity ink ,
1- try to open and close the ink cartidge more than once .
2- before that check the cartidge front out let ( should be opend) by turning the niylon on it , this should be done when inserting the cartidge.
Oct 28, 2010 | Brother Multi-Function Center MFC-240C...
When printing, the colour black is too light. Other colours are ok. what to do ?
it happen when the black ink is low or ink outlet get block;just replace your black cartidge it will sove your problem;]
let me know if it's helpful to you
Dec 05, 2009 | Xerox Phaser 6125 Laser Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Jan 23, 2008 | Lexmark Z1420 Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
351 people viewed this question
old marine
old marine
