Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
I want to record a dvd from my tv/dvd/vcr combo to an external vcr. i'm not trying to break any laws, it's only for my babygirls personal enjoyment. please tell me how the wires should be
  • amy patterson Oct 16, 2008
    my tv/vcr/dvd combo is too old, i guess. it's only got the cable connection and a coaxial port in the back, and just one set of rca plugs in front. i don't know enough about what i'm doing to know if the jacks in the front are input or output. am i just out of luck???
  • 128 Answers
As long as you're not breaking any laws you can connect the video/audio output of your combo unit to the video/audio input of your vcr using audio/video rca cables where the yellow plug goes to the video input/output and the red plug to the right audio and the white to the left audio input/output.
Posted on Oct 16, 2008
  • cpenny29 Oct 17, 2008
    if the front jacks doesn't indicate audio/video out, or in, best thing to is try it! connect the said rca cable to your vcr as stated and try to record for a few seconds and see if you can view your recorded scene,nothing comes out then the front jacks are input. this process will not harm your system.
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
DVD and VCR recorder with this product?
As long as you have Composite/SVHS Video Input, Usually a Yellow RCA Socket or a 4 pin Mini-DIN & red & White, AV (Audio Visual) RCA sockets on the machine, AND you can select an "External" input, then YES anything that can connect with this way will work.
Feb 10, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Can you record a dvd from vhs on this system ?
No you cannot - This is a DVD *PLAYER* / VCR combo - which means it features a DVD player & VHS recorder in one - you cannot record onto DVD - You can however watch a DVD while recording your tv program on the VCR.
I hope this answers your question.
If you want to convert your VHS to DVD you will need to purchase a standalone DVD recorder - I personally do not reocmmend the DVD recorder / VCR combos - or you can use a HDD/DVD recorder which stores recordings on a hard drive and later you can burn them on DVD, they allow editing, more flexible recording options, etc
Aug 17, 2009 | Toshiba SD-V291 DVD Player/VCR
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
My dvd/vcr combo will not record
follow the below link>>
http://www.geocities.com/toddemslie/vcrdx.html
Hope it helps.
Thanks
Oct 22, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Connecting the DVD recorder to a Sylvania TV combo w/TV & VCR
Is the tv a combo unit and has a vcr. well, the way this dvd recorder works it needs the signal of the material that is wanting to be recorded. fortunately it doesn't see anything else without some type of cable of some sort. just with the color cables it just acts like a regular dvd player. the best thing to do is get a hold of a external vcr and run color cables to this dvd recorder and then another set of color cables to your tv and put it on your VIDEO channel. refer to page 34 where it says connections for an external source. it illustrates it will and read carefully. sources: I USED TO WORK FOR THIS COMPANY;)
Sep 29, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
89 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
