UNKNOWN  COMPUTORS  CONNECTED  TO  MY  NETWORK  I  AM  USING  A  WIRELESS   MODEM  P2602  ANY  HELPERS
  • 781 Answers
Avery you need to configure your router to avoid having people using your internet conection:
please provide the model and maker of your router and I can walk you through a desirable configuration. or if you want to try it yourself check on your router's manual as usually there will be instructions on what you need to do...
for you to have a general idea i suggest your read the following article that explains common things you need to set up like:
1. change the default SSID (the network name or name of your router/access point)
2. hide your ssid (so only you know the name and set up the computers you want manually to use it)
3. a network key/passphrase: so in order for other computer to join your network a key/passphrase or password is provided first
4. encryption: so your neigbors don't decipher what you're transmitting wirelessly.
5. configure your computer to access your wireless network after configure your router with the configuration you set.
http://www.home-network-help.com/wireless-router.html
if you have any questions post back and make sure to note the router model and maker
Posted on Oct 16, 2008
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
I have a Motorola SURFboard Gateway SBG6580 modem. I want to use the wireless for my DS lite but it says that I need an WEP key, but I don't know how to enable it. Help!
Your wireless is set up with a password. You need to get that password before you can connect any more devices. From a computer that can connect to the internet go to 192.168.0.1. Then type admin for the username and motorola for the password. I believe from there you click Wireless then click Primary Network. You should see your wireless network name and password from there. I'm getting this from the modems manual here: http://www.midcocomm.com/_files/files/SBG6580.pdf
Oct 16, 2012 | Arris SURFboard® SB5101 Cable Modem
How do i connect my wireless internet
Connect your wireless modem into the telephone or ADSL capable line from your phone company or internet service provider (ISP.) Remember to place an line filter between any hard-wired phone and also the modem. (The modem will have at least one in the box, use it for the modem.) Open the modem box and read all the instructions carefully. Connect your PC with a CAT5 (RJ45) cable in the modem box to the modem... yes, you need to use a cable to set it up. This is bit wider than the normal telephone jack and there is a place for it on your PC called an "Ethernet" plug. The modem should have a CD ROM that will help you set it up. Before you begin, make up a unique, easy-to-remember name for your network, also think of a password that you want to use to secure your wireless connection. Call your ISP and tell them what the brand and model of your wireless modem is and they will talk you through the set-up at no cost. The key thing to have handy is the "Default gateway URL" This is sequence of numbers and periods between them that is absolutely essential to set up your wireless modem. If you don't have it, don't worry... there is a command prompt (CMD) that your ISP will instruct you to use to retrieve it after you have installed the modem's driver and are ready to set it up. Normally, the first 2 to 4 passwords required are to get access to set up the modem... using "admin" is just fine. (Passwords are most always asked in duplicate to reconfirm the password.) The important password is the one that allows access to your home or business wireless network. Remember to write down your username, unique password, and the network name for your network and the Default gateway URL so you can easily diagnose connection problems later. I keep this stuff in the modem box with the cable, instructions, and CD. Good Luck
Oct 05, 2012 | Panasonic TC-P42G15 Plasma TV
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Sep 28, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
We have more than one computor in the house and we have reset arris box in order to connect........... in the process the computor that is connected will get booted off the internet...isnt it possible to...
All the computers in the house should connect to the netgear wireless.
The netgear should in turn connect to the arris modem.
And yes, all the computers should be able to access the internet at the same time when setup this way. You shouldn't have to reset the modem at all.
Jan 24, 2011 | NetGear (WG602MES) 802.11g/b Wireless...
I AM ON TOTAL BROADBAND HOW DO I CONNECT WIRELESS TO MY COMPUTOR
With a broadband connection you will need a wireless router (you will connect your broadband modem to the router) a wireless adaptor for every computer you want to be wireless. If you have a desktop you can either add a pci wireless card (you will need to open your pc and insert the card in a pci slot) or you can use a usb wireless adaptor.
Oct 28, 2009 | Computers & Internet
Huawei EC325 wireless modem not detecting network
not compatible for fiji network. try to call their customer support. some isp is using mac addressing for clients for connectivity, means if its true then the mac address of your modem is unknown to fiji network.
Jan 20, 2009 | Linksys Wireless-G WRTP54G Router
Getting wireless computor and router back on line with desk top computor
1. Disconnect power from your modem and router
2. Connect an ethernet cord from your modem's ethernet port to your router's Internet or WAN port.
3. Connect another ethernet cord from a port on your router (labeled with a "1" above it).
4. Connect power to your modem and router.
5. I'm a little unsure about how you plan to connect your wireless computer to the router. The router you selected when you created this question is not wireless-capable.
If your router is wireless-capable, go to the wireless computer. Follow the instructions for your operating system below.
Windows XP
1. Right-click on the My Network Places icon on your desktop, and select Properties.
2. Right-click on Wireless Network Connection.
3. Right-click on View Available Wireless Networks.
4. Double-click on your network from the list that appears (it should be called "linksys" if you didn't change the name).
Windows Vista
1. Click on the network icon on the lower-right of your screen (it should look like two computers with one behind another. It might have a red "X" over it.)
2. Click "Connect to a network" (it also might be labeled "Connect or disconnect")
3. Double-click on your network from the list (it should be called "linksys" if you didn't change the name.
Mac OS X
1. Click on the AirPort menu in the upper right of your screen (it looks like "("s turned on their side).
2. Click on your network in the list that appears (it should be called "linksys" if you didn't change the name).
Sep 30, 2008 | Linksys EtherFast Cable/DSL Router
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
