I have roadrunner internet and when i connect it directly to the main desktop computer it works fine but when i put it through a linksys router the internert doe snot work and the rest of the computers in the house dont get internet either.
  • 6,487 Answers
You need first to configure the linksys router to work with your road runner cable internet, if you have the setup CD for the router you can use to configure the router but if not you need to manually configure the router to work with Road runner cable internet by accessing the router setup page, if you're not aware on how to manually configure the router to work with road runner you can call this number so a Tech can walk you through with the process 1-877-787-8749...
Posted on Oct 16, 2008
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Linksys wireless was fine on my lan line now cable it is not?
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Problem with network
Make sure the physical connections are correct. Modem connected to the Internet Port of the router and your PC to port number 1 on the Linksys router as well. Try to reset the router. Hold the reset button at the back of the router for about 20 seconds. After that, unplug the power to the router and to the cable modem. Wait for 30 seconds. Plug the modem first, wait for the lights to stop blinking then plug in the router. Check if the internet works fine again.
Sep 06, 2008 | Linksys Computers & Internet
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Mar 24, 2008 | NetGear WGR614 Router
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
