Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire ultra quiet I dishwasher
I tried to run the dishwasher and it sounded fine at first, but when it went to the 'wash' cycle, it started making this weird high pitched buzzing sound. when i opened it, it smelled like it was burning and there wasnt any water in there. well there was but it was more like condensation. any ideas anout whats wrong?
  • mda11507 Oct 16, 2008
    oh yea, one more thing, the spinning thingy wasnt spinning either
  • 3 Answers
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Posted on Oct 29, 2008
My frigidaire ultra quiet III dishwasher sticks on wash cycle. whats wrong?
Good Morning friend, thanks for your inquiry!
From the information you have provided your Frigidaire dishwasher is sticking on the wash cycle. Do you mean the button is sticking? Or is it stuck on that cycle? If the button is stuck you may have an issue with your keypad and in order to help unstick the button I would push it down to see if that helps alleviate any tension.
If you dishwasher is stuck on the wash cycle I would recommend performing a reset and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to have an issue with your cycles I would suggest having a professional out to properly diagnosis and replace any electrical components. I hope this information has been helpful. -Matt
Apr 06, 2015 | Frigidaire Dishwashers
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Wash cycle knob
It's a quirk of the cycle timer. You can replace the timer ($) or live with it. Besides, a replacement might have the same quirk
Jul 15, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Noisy drain pump on FDB635RF?
    Two questions: 1) Are there filters that need to be cleaned on a routine basis with the FDB635RF? and 2) What causes the scum left behind on glasses and utensils? I use a rinse aid, but doesn't seem to be helping. This is a recent problem.
    Apr 22, 2010 | Frigidaire 24 in. FDB635RF Built-in...
    Won't turn on. Frigidaire, precision wash, ultra quiet 1
    I have the same issue and it occurred around the same time as your post. Do you think there is a conspiracy? :-)
    Feb 28, 2010 | Frigidaire 24 in. FDB126RB Built-in...
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    Loud Buzzing Sound from Dishwasher
    have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
    Jul 30, 2009 | Dishwashers
    I have a Frigidaire Ultra Quiet Plus dishwasher. The top spray arm isn't spinning during wash. The bottom spins fine and I can spin the top freely by hand. It appears there is not enough water pressure...
    I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
    www.frigidaire.com/support/FAQ-Dishwasher.asp#6
    Oct 20, 2008 | Frigidaire Dishwashers
    Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
    893 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
