Question about Carrier YCB213D Air Conditioner
Fan blows but compressor does not run.
I took off the front grill and blew out the coil with an air compressor but now the fan blows but no cool air. The compressor is not kicking in. Any ideas?
    Problem Solver:
  • 14 Answers
Turn off asap! the compressor is the heart of your system, so it might need a hard start it gives it more power if that does not work be ready to pay for a new outside part
Posted on Oct 16, 2008
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
Exterior CKL49-1A AC Unit not blowing cold air
Why you need to change evaporator coil when condenser fan not working ,also why would you even charge unit with looking for leak.
Maybe the evaporator coil is leaking and when you recharge it it work for couple of days now unit is empty again .
If unit have low pressure switch then outside unit would shut off.
Jan 05, 2018 | Coleman Heating & Cooling
Outside surface gets hot to touch
The most likely problem is a dirty or clogged up condenser grill (under your unit). When the condenser grill is dirty it can get rid of the system heat build up, so it transfers the heat to the cabinet.
Remove the front grill and vacuum it the best you can, a small brush would help loosen up the dirt. Then move the unit away from the wall and remove the rear panel and use an air compressor to blow it out.
Make sure that the condenser fan is operating or that could also be the problem.
If none of this remedies the problem then your unit could need to be charged with freon. Because if the freon is low the compressor has to work harder to cool.
Aug 07, 2011 | Kenmore Top Freezer Refrigerator
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
Subzero 501F is not freezing well. Top shelf and top door shelf of freezer stock melted and began to rot. Bottom 3/4 is staying solid and frozen.\r\n 22year+ old unit. Had a 25 year old one at other house...
sounds like you have a bad evaporator fan motor,heat rises,if the fan isn't blowing the cold air will settle to the bottom and the top will be warm,also when was the last time you cleaned the condenser coil ?very important to do this at least once a year, shut down the machine,remove the front grill,remove the cover on the left side,,with a shop vac and brush attachment vac off the face of the coil ,now get a towel and cover the cabinet where the front grill was, you can open the door,stick the towel in and close the door to hold the towel in place,set the shop vac up to blow and blow through the right side of the coil,the towel will stop all of the dust from blowing into your kitchen,do this a few times,remove the towel and vac up all the dust that blew out of the coil,set the towel up again and blow through the other side if you can and blow into the coil where the fan is,do that a few times,you can hang the towel and just blow into the cabinet so all the dust that you can't vac up off of the walls and behind the compressor will blow forwards,also i've found some coils loaded with grease,people don't use the hood vents when they cook the oil and grease floats into the condenser fan in the subby and gets into the coil,if so spray it down with grease lightning or any kind of chemical that cleans grease,wipe it down and blow through it a few more times,gotta have good air flow in there or you'll be changing out the condenser fan motor or compressor.from what you discribed check the evap fan motor and clean the coil at least once a year
Jun 15, 2011 | APW Wyott SubZero Refrigerator Freezer...
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
My whirlpool fridge is hot, took the cover off of the coils inside freezer, look ok. Took back cover off of the back and the compressor is hot
Hi jason;
Shall take it that you have a Side by Side setup? If so with rear cover off, when you start it does the cooling fan come on beside compressor? Also remove front grille and clean front condensor coils, full dust and hair all problems can happen. (like blocking of car radiator). Try these if fan doesn't work, replace.
Mar 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators is not blowing cool enough air to freeze or cool each side respectively.
I assume the compressor is running since you indicate you have some cool air.
Check to make sure the compressor fan is running. This fan should be near the compressor. Its purpose is to pull room air across the coils and remove the heat from them. If this fan does not operate properly, the refrigerant will not be cycled properly. If the fan is not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
1 yr old 15,000 btu Coleman fan blows compressor not working
The power supply or compressor coil may be faulty. There could be shorted wire, open circuit, bad relay.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Carrier YCB213D Air Conditioner Logo
166 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
