Question about T-Mobile Sidekick ID Cellular Phone
Sim card problems
Also, to add to the problem ,when I try to make a call or recieve a call, sometimes we don't hear each other... why is that??
    Sniper:
  • 66 Answers
Better check all the mic piece and earpiece both your cellphone. im sure there have been a problem.
Posted on Oct 16, 2008
How do you remove your sim card from the 6700 slide to replace with new?
I don't have this particular phone, but generally the sim card in under the battery. Before you start, make sure you have all your contacts and stuff stored on the phone, not the sim, or it all goes bye-bye when you change the sim. Snap off the back of the phone. Don't pry the battery out. Usually you have to look for 2 tiny little "latches" that hold it in. Sometimes there is a lever that you push to release the battery. Then you can see the sim card. Sometimes you release a little metal clip that holds it down. On other phones, you just slide the card out from under the metal holder. Pay attention to which way the card is turned, and don't put the new one in upside down. Then reassemble the phone.
Feb 01, 2012 | Nokia 6700 Slide Cell Phone
Went off when i make calls/recieve but works fine through earplugs
Hi reachmehe822 I not sure which phone you have. Now her is a few universal steps you can do. One take the battery and sim card out of the phone. Two clean out of speakers and mic ports. Three take a toothbrush and a can of air to clean the phone. Don't spray the air to long in your ports. Next do not spray to long in the speakers or mic. Now if your can gets cold let it warm up for 5-10 mins. Now I would but the sim card in first then the battery. You should be able to hear out of the phone. Hope this help.
Sep 19, 2011 | Cell Phones
Can recieve messages but cant send
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jul 18, 2011 | Cell Phones
Why can't i recieve text messages on my samsung
Hope that helps.
Jun 17, 2011 | Samsung Cell Phones
I have a reasonably new 6120 but as of this morning people cannot hear me talk. I had the same problem with my N85 which stopped suddenly also.
If you used a same SIM card for those phones, I think its signal problem, when signal is low the connection will be disturbed sometime as no sound or cut suddenly during call conversation. Try to use different SIM card provider, with stronger signal will better, then put in these device. If the problem solved then its operator signal problem. The solution is change the SIM card.
But if you have try to change with other SIM card with stronger signal but people still can't hear you, then its microphone problem. You need to repair or replace your phone's microphone.
Hope this help and if this helpful RATE please.
Feb 03, 2011 | Nokia 6120
Lost outgoing voice signal. Can dial out, recieve calls & hear
Your problem is with the mic, probably it's not working anymore or maybe it's been displaced or wiring problem. It's better for you to get it repaired from a mobile repairing shop. You might make mistakes if you don't have enough idea with it. They'll replace the mic and the problem will be fixed. Good luck Thank you for using FixYa.
Jun 01, 2010 | Nokia 6131 Cellular Phone
Unable to send or recieve calls and texts. It is not the sim card
try using a different sim in your set to confirm whether it is a set problem or sim problem. If it is a set problem, restore the factory settings.
Jun 20, 2009 | LG TRAX Cellular Phone
6230 problem
Your phone is dying, replace it, it probably got fall or got electricity circuit during the charging
Jun 29, 2008 | Nokia 6230
2 problems; first cant hear from reciever, only when on speaker phone. Second speaker whistling when on speaker phone.
the whistle could be from teh sim-card take it out and place it into another mobile if you do not hear the sound anymore have the sim-card replaced.....as for the ear piece take the phone to a mobile service center or professional mobile technician to hvae it replaced.
Mar 02, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Se k800i cant recieve sms
I think the problem is your phone has some settings that disabled your SMS functions so I suggest you to try and put your SIM card in another phone and try sendng SMS. If it works, try Reset Settings from the K800i. If it doesn't work, try changing a SIM card from your service provider.
Aug 30, 2007 | Sony Ericsson K800i Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
20 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
