WHIRLPOOL DUET 9100 STOPPED UP DRAIN IN SPIN CYCLE F02 BLINKS.
F 02 BLINKS AND I KNOW THE PROBLEM IS THE DRAIN IN THE SPIN CYCLE IS STOPPED UP. IT MAKES A NOISE AND IT HAS DONE THIS BEFORE. I FORGOT HOW TO TAKE THE WASHER APART TO GET IN IT AND FIX IT. THE LAST TIME A TECHNICIAN CAME OUT AND THIS WAS THE PROBLEM THEN ALSO. I AM A DO IT YOURSELF PERSON. CAN YOU PLEASE GIVE ME DIRECTIONS ON HOW TO GET THE TOP AND BOTTOM OFF THE WASHER SO I CAN CLEAN OUT THE STUFF A 12 YEAR OLD LEASVES IN HIS POCKETS!!! THANK YOU PAULA
    Novelist:
    Champion:
  • 261 Answers
I looked up a pic of a model ghw 9100 for you to look at as reference. There is a kick panel with three screws. Either a 1/4 inch socket or a torx T20.
Posted on Oct 16, 2008
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer has an F02 code in the middle of the cycle, which has stopped, and I don't have the manual.
F02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
"F/02" is flashed.
The most common cause is a clogged drain filter. Remove your lower front panel. The filter is located in the discharge hose before the pump (often white in color).
Remove the filter and clean out any debris (socks, nails, coins etc..)
If this is not the problem then here is directly fronm the manual.
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a GHW9100LWl washer. It sometimes flashes F02 and stops. Alson when it is in the spin cycle, it is very loud and had a knocking sound. Please help.
Hi
F02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Got code F02 after cleaning all drain system and replacing pump.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer flashes a 02 error during the final spin/drain cycle.
f02 is a fault indicating poor drainage, try removing hte front access panel and cleaning out the pump housing!
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 02 code is flashing
F02 indicates "Long Drain"
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
