Question about ASUS P5P800-VM Motherboard
Asus p5p800 motherboard
Ive got asus p5p800 vm running on p4 ht 3.2gig,2 gig ram,160 hard drive i shut it down as normal as was running brilliantly,turn off by mains and disconnected as was going to sort out another pc,left it for few weeks and decided to put back on,lights came on board fan working no display hard drive working and dvd drives all working,usb keyboard no longer ligthing up or working,a month ago i put an ati radeon graphics card x1650 dd2 agp after upgrading from nivida fx550 256,thats when i got restarting problems{was told its over heating or power supply but not as ive got pci cooling fan for card and power supply 600w.went to turn off pc by power off button on case will not turn off computer had to do by power suppy{which it did when last used.put back in old graphics card is working and same tryed pci graphics card and same,removed 1 ram at a time still same hard drive,barebone it still same.shouldn,t be cpu as working fine could this be bios chip problem or main board naffed.any help or solution will be appreciated thanks
  • Anonymous Jan 10, 2009
    I have the same exact problem... checked all the voltages coming from the PSU and they all check out. Anyone else have any ideas?
  • 849 Answers
Seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Posted on Nov 21, 2008
Only utilizes 3 of my 4 gigs of RAM
Asus will explain why. Open the link provided and type, P5P800-VM in the Search window on the right upper corner; http://support.asus.com/download/download.aspx?SLanguage=en-us
Click on: P5P800-VM related FAQ.
Don't be fooled. I have installed XP 64bit and windows XP still reports 3GB.
Cheers!
Mike
Oct 15, 2009 | ASUS P5P800-VM Motherboard
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
Compatibility issues.
That board will support a P4, Celeron D, or a Pentium D.
Jul 16, 2009 | ASUS P5P800-VM Motherboard
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Wont display monitor or KB/M
Boss, sy mencari driver mainboard Asus p5800-vm. Sy kesulitan mencari free-nya mohon dikasih linknya & bs email balik ke saya sugik.blora@gmail.com terimaksih.
Jan 19, 2009 | ASUS P5P800-VM Motherboard
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
Hard drive compatibility
This motherboard is compatible with PATA/IDE Hd's running at 133/66/33Mbs. & ATA/SATA 1.5Mbs drives. The SATA's run faster. This board will not handle a SATA II's speed but it will still run on the P5P800-VM board. The links below show good buy's on both PATA/IDE & SATA I & II. Seagates for their 5yr. warranty.
Seagate ST3160215AS 160GB ATA/SATA
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117012
Seagate ST3160215A 160GB Ultra ATA/100
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117010
As far a size, that is up too you. Windows can handle 5 time these sizes.
Please don't forget to vote.....
Dec 22, 2007 | ASUS P5P800-VM Motherboard
ASUS P5P800-VM Motherboard Logo
274 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
