Question about Dryers
I have an Admiral electric dryer that is 3 years old. Earlier this evening I dried a load of clothes and when I reloaded it again, it will not come on. The interior light will come on and the door switch clicks if I push on it. Can you help me solve the problem. We have checked the breaker and even turned it off and back on, but no luck.
  • waltonwendy Oct 17, 2008
    Thank you TBlessed1 for your help. When we tried the dryer this morning, it worked fine. We are now wondering if it just overloaded and a safety switch turned it off in order to cool down.
    Scholar:
  • 61 Answers
The dryer has a overload type fuse that blew out the wiring diagram might show you where but it should be either on or near the motor and also check the switch contact where door closes....
Posted on Oct 16, 2008
  • Rod
    Rod Oct 17, 2008
    yes that is the purpose of the overload before break the fuse entirely.... Be Blessed! your welcome..
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
I have an Admiral gas dryer. It's about 2 years old and today I noticed it is not drying clothes. It is turning on but there is no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-
Sep 18, 2011 | Dryers
My electric Whirlpool clothes dryer (model #LER 5636EQ3) about 9 years old, will not dry a load of clothes in just one cycle. I have to dry some things 2 or 3 times before the clothes are dry. I clean out...
Check your electrical power going to the dryer at where you plug the plug in at the receptical. and make sure you have 120 volts on each leg, it sounds like you may have one leg with 120 volt and the other leg with no voltage. I hope this helped. Please rate me, Thanks
Dec 30, 2009 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
I have an Admiral dryer that is over heating. Its
bad high temp. theremostat on heater box-mike
Mar 14, 2009 | Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
