TV will not stay on when it is turned on and red lights flash, 1 then a few second delay and then 2 more red lights flsh. Philips said system is refusing to turn on because something is wrong and it is protecting itself
    Sergeant:
    Champion:
  • 227 Answers
The first thing you have to do is disconnected the tv from the power outlet and wait for a couple of hours and then try it again
caypianan@yahoo.com
Posted on Oct 16, 2008
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
I have a 50" Philips
Most likely the power supply capacitors are going bad.
Opening the TV and replacing any swollen caps may solve your issue.
Thanks
Roety
Aug 16, 2011 | Philips Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips Magnavox Learning Universal Remote
Philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
Feb 13, 2009 | Apex Digital AT2002S 20" TV
Red Blinking Light/No Picture
7 blinks? Many have replaced caps on the SMPS board, with success: 2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 1 00μF 25v. Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Jul 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 50PF9631D Plasma
First step....check power supply components.....research
similar Model & problem.................T.
Mar 22, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
