Question about SanDisk Sansa e140 MP3 Player
SanDisk e140 with Mac OS x
I got an old SanDisk Sansa e140 that is still working fine.  It work on my PC but my IMac does not recognize it.  When I plug it in, the mp3 player start saying "USB Connected" but no icon appears on the computer's desktop. Can anyboby help me, I have visit the SanDisk forum but there is no solution for the old mp3 player.
SOURCE:
SOURCE: my mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Posted on Dec 05, 2006
Jessamole
SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Posted on May 09, 2007
SOURCE: pb for my sandisk m230 mp3 player
Same thing happened to me... try this...
1) disconnect all cables
2) turn power on (hold menu button until screen lights up)
3) Press "menu"
4) scroll down to "settings"
5) scroll down to "USB"
6) select "MSC" (default is probably auto detect - which I think there's a conflict with)
7) turn power off (holding the menu button down)
8) connect USB to computer and hopefully start loading files
I bought 2 of the 512 models, one didn't work... so I took it back and had to buy a 2gig model... got home and it didn't work! I tried the above for the new one and at least the computer recognizes it! Everything seems to work fine...for now...
Posted on Dec 13, 2007
SOURCE: sansa e200 / apple imac
it should recognize it as a usb drive
Posted on Jul 30, 2008
  • 684 Answers
SOURCE: Sansa e140 error
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
Posted on Aug 03, 2008
My SanDisk is a portable USB/ compatible to IMAC?
although your mp3 player may not officially be imac compatible, it should still plug in and be recognized by your imac just fine, you just wont be able to use any software that may or may not come with the mp3 player, however given that its not a zune (microsoft product) and that its not an ipod, it should work perfectly fine, and you should be able to simply drag and drop your music onto the mp3 player when it is recognized by your imac. just be sure to copy the files over to it while its plugged in by using the file browser of your mac.
Feb 20, 2014 | SanDisk Sansa m240 MP3 Player
Hey can you tell me how to fi this problem my san disk e140 is telling me not enough memory cnnect to the pc delete 4m of songs for sansa system.i have tried everything it told me and it still do not work...
to solve the problem do the following things:
- download the firmware (http://www.sandisk.com/Retail/Default.aspx?CatID=1295)
- run firmware - SW
- FirmwareDownloader shows "Detecting"
- put oft the battery of the e140
- hold down the Power Button
- Connect the e140 to the PC
- FirmwareDownloader shows "Recovery mode ready"
- press start-Button
--> e140 works
Sep 28, 2008 | SanDisk Sansa e140 MP3 Player
Sansa e140 error
Aug 03, 2008 | SanDisk Sansa e140 MP3 Player
E140 stopped working
I think u can call this customer service ph# 800-426-6027 to get assistance on service
Apr 04, 2008 | SanDisk Sansa e140 MP3 Player
Sandisk sansa e140
U can try to contact the Sandisk Company at 800-426-6027 and they will have a solution for this problem
Jan 25, 2008 | SanDisk Sansa e140 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Won't recognize music files
My Sansa only reads mp3 or WMA files, not mp4 files.
also, i have tried three different computers, and all of them recognize (or NOT) my player differently....
~Rebecca~
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
No change is recognized in the playlist
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
Detected by the pc but no changes are made
On the Mp3 player u will see a small slide switch which says Hold/Unhold try to slide that switch to the opposite direction
Nov 14, 2007 | SanDisk Sansa e140 MP3 Player
Not detecting sansae140
Pls call the customer service Ph# 800-426-6027 they will help u out with it
May 30, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
