Question about Amana Dryers
How to replace heating element in Amana Clothes Dryer
    Scholar:
  • 61 Answers
When changing heat elements it's best to replace them all they are sometimes sold as kits there are high and low temperature elements that are tin like devices about the size of a qauter and larger and when you get the kit it might have 2 or 4 devices that are pretty simple to change because it will be hard to know which element is bad and the parts are an easy match but the hard part might be finding all of them that easy because each element are in different location on a dryer follow the wiring diagram or look carefully until all or most of the elements are found and replaced....
Posted on Oct 16, 2008
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
My Amana 7200 Dryer will not heat???
Heating element in drier may be burnt out.
Nov 12, 2012 | Amana Dryers
My electric amana dryer heats up but does not seem to blow the heat around and the lint is only gathering at the bottom of the lint trap, so it takes forever to dry my clothes. What do I need to do?
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Amana ALE230RAW Electric Dryer
It is not heating up
There could be a couple of problems. First, ensure the vent line is clear. If it is stopped up, this will cause the dryer to go out on overtemp and will not dry your clothes. Second, the overtemp sensor could be bad and not letting your heater element to energize. And third, your heating element could be shot. I have attached a link to Amana's owner manual for your dryer.
http://shop.amana.com/assets/pdfs/literature/40119701.PDF
Jul 17, 2010 | Amana DLE330RAW Electric Dryer
Super capacity Amana dryer is less than 3 years old. It no longer dries the clothes. There is no heat.
check your heating element in the back of the unit for breaks, if there is not heat that is your problem. the other issue can be a fuse that blew not letting power get to the heating element but the easiest and cheapest thing to look at first is the heating element
Jan 10, 2010 | Amana DLE330RAW Electric Dryer
Amana Special Edition Electric Dryer Model ALE868QAW not drying
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Dryers Logo
523 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
