Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
60 inch sony wega tv
This is the third time something has gone wrong with this tv. When you turn it on the green light flashes 3 times then it starts flashing red and the picture wont come n
  • gdjfg Oct 19, 2008
    I have a KDF46E2000 and the same problem is happeneing. It was fixed in the past by pulling the lamp out and reinserting it, but now that doesn't work either
  • gdjfg Nov 10, 2008
    I can get mine to work for about five minutes and then it shuts down (3 red flashes) If I unlock the lamp cover handle and then lock it shortly after it has turned off, the tv won't turn on, but if I wait 10 minutes and do the same, it will turn on for about 5 minutes again. I've had Sony techs out twice to fix this and they are now figuring it may be the boards the switches are connected to because the switches seem to be working? All of this started when I had the optical block replaced so I think something got damaged when thr repair took place..I'm hoping! (KDF-46E2000)
    Novelist:
  • 135 Answers
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Posted on Nov 10, 2008
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
60 inch sony wega lcd projection
Possible themal sensor. Easy to bypass too!!! Check with authorized Sony repair facility.
Dec 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
557 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
